View Poll Results: Was this thread helpful?
Hell yes! Very useful for the community!
321
98.17%
No way, I still don't know what filter I need!
1.83%
Voters: 327. You may not vote on this poll
The OFFICIAL Oil Filter Testing and Results Thread (4G63T/4B11T)
Old Nov 30, 2020 | 12:40 AM
  #421
ace33joe's Avatar
PL14459 seems also hard to come by at online stores, PBL14461 seems longer (less ground clearance),
Since 2005 or so, has been using Wix filters in earlier years, and Hyundai TUIX oil filters so far (high performance version of Hyundai OEM but also discontinued.....),
and need to stock up some good quality oil filters.
Any recommended source for Purolator filters?
Old Apr 19, 2021 | 09:57 AM
  #422
phantastic's Avatar
much appreciate this informative post! you're a f#kn superstar!
Old Apr 19, 2021 | 10:00 AM
  #423
golgo13's Avatar
EvoM Community Team
Veteran: Navy
Cool
Glad this thread is still going. I'm sure it's WAY out of date now though. Probably a lot of those filters have changed or have been discontinued a this point. Maybe someone else can pick-up the mantle and start a new thread!
Old Apr 19, 2021 | 03:18 PM
  #424
kaj's Avatar
kaj
I've always stuck with the Wix.
Old Apr 19, 2021 | 06:33 PM
  #425
bboypuertoroc's Avatar
Veteran: Army
I've been using Wix for years now.
Old Apr 28, 2021 | 12:56 PM
  #426
RSMike's Avatar
There is some fantastic info in this thread.
One of the key points i've taken away from all of this, is the Evo platform needs a bigger filter.
If the bypass valve in the filter is opening at ~5000rpm, then you have unfiltered oil going into the engine.
So why not use a filter that's double or triple in size like the Wix 51515XP?
https://www.rockauto.com/en/moreinfo...=4768938&jsn=3
It looks like a case of the more filter surface area you have for a given media, then the less pressure drop. This means you're less likely to open the bypass valve unless it's been blocked/clogged by particles.
The packaging of the oil filter housing on the Evo restricts big filters - so why isn't oil filter relocation kits more common on Evo's?
I know what i'll be doing next!
Old Nov 23, 2021 | 05:06 AM
  #427
RWD4G63's Avatar
Looks like a few of these filter companies have recently changed hands and therefore changed quality. Wix was bought by another umbrella corporation. Purolator has changed their filter design. Fram now has their "ultra" line or whatever.
Old Jul 8, 2022 | 03:43 PM
  #428
RSMike's Avatar
Some more oil filter info that I did a while back.
https://www.evolutionm.net/forums/ev...-md356000.html
Old Feb 11, 2023 | 11:39 AM
  #429
osetsky's Avatar
Now that Wix are junk(
) what's good?
Old Feb 11, 2023 | 12:45 PM
  #430
kaj's Avatar
kaj
Originally Posted by osetsky
Now that Wix are junk( https://www.youtube.com/watch?v=x0YYhq3kYfA ) what's good?
What makes it junk?
Old Feb 12, 2023 | 09:41 PM
  #431
osetsky's Avatar
Okay fine, not junk exactly though a lower quality now that production has been offshored and it would appear material switch as well. Plus keep this place lively, duh.
Old Feb 14, 2023 | 02:02 PM
  #432
kyoo's Avatar
i been using fram ultras for so long
Old May 30, 2023 | 01:42 PM
  #433
4wd4me's Avatar
Originally Posted by kyoo
FYI, fram ultra xg3593a is a confirmed fit, if there were any doubt.
thanks for this, well probably go this route as our usual go-to is now discontinued (K&N HP1010)
Old Nov 1, 2023 | 07:39 AM
  #434
nguyenandy91's Avatar
Not sure if anybody has seen this video yet. Apparently Purolator Boss is pretty top notch
Old Jun 6, 2024 | 03:25 PM
  #435
kyoo's Avatar
semi necro, what's the easy button ont he oil filter (amazon)?
they don't seem to properly sell the xg3593a anymore, which was my go-to. excellent filtration and flow. not sure where to go now.
