Bearing Suggestion
Old Nov 26, 2012 | 10:11 AM
TURBO_S2K's Avatar
Bearing Suggestion
I am building my block
I need suggestions on main/rod bearings
The setup is:
10.5 CR CP Pistons (for Long Rods)
156mm Carrillo Rods
Stock Crankshaft
As for the bearings, I only found the sizes for Tomei
If I do get Tomei, I will need the Grade A ''Black'' Bearings (1.985~1.988)
I am considering ACL since they are much cheaper. Which ACL Bearing will I need?? (that is the same size with the Black Tomei Bearings)
Or should I stick with the Tomei? Is it really worth that much more compared to ACL?
Old Nov 26, 2012 | 10:24 AM
okevolutionVIII's Avatar
If the cranks journals are all good and don't need to be cut, get standard size ACL, Kings, Cosworth, or Clevite. All but the Cosworths are priced great with no benefits over the others. I would honestly buy whatever set you can find cheapest and not worry too much about it as they're all very good brands.
elhalisf
Oct 28, 2018 11:50 AM
drewgray
14
Jan 3, 2013 07:48 AM
mberenis
10
Nov 28, 2012 07:54 AM
TURBO_S2K
Nov 17, 2012 07:23 PM
gidz
May 21, 2012 08:32 AM
