ACL Rod/Main Bearings Extra Oil Clearance?
Old Dec 4, 2008 | 11:15 AM
elhalisf's Avatar
I am in the market for ACL coated bearings, and they seem to have two different types of standard size bearings.
One with standard oil clearance and the other with an extra 0.001" oil clearance.
I know a good oil clearance is for the main and rod bearings to be about 0.002". What is the advantage and disadvantage of running 0.003" oil clearance? 0.003" is still within the factory manual limit for both the rod and main bearings.
Old Oct 25, 2018 | 04:53 PM
stunna2o1's Avatar
Ever get any good info on this? I know I’m ten years late lol
Old Oct 25, 2018 | 05:03 PM
Pal215's Avatar
There are a couple of reasons for tighter or looser clearances, but the main focuses are oil weight, high rpm safety, temperature, and journal distortion. The end goal is to not spin a bearing. Choosing the right size bearing also helps keep bearing crush pressure in check!
In short, your rod and crank journals ride on top of an oil film that is held by your rod and main bearings when oil pressure is present. You want to maximize this oil film strength, but it can vary based on total power output and RPM.
This article contains more detail if you are interested.
http://www.enginebuildermag.com/2013...ng-clearances/
Old Oct 25, 2018 | 11:28 PM
stunna2o1's Avatar
Very good read, thank you. So say I have a stock bore Evo 8 block with clean honed cylinders. Have a brand new 88mm manley crank, standard forged Manley pistons, Manley h beans, and plan to make about 550whp on an fp black. For main and rods do I go with the standard acl bearings or the standard acl’s with .001 oil clearance?
And for which decision I chose what oil weight is preferred?
Of course all clearances will be double checked when assembled
Seems to be a tough thing to research because there are so many different opinions with so many different types of builds.
Old Oct 26, 2018 | 12:05 AM
Pal215's Avatar
No Problem. As far as standard ACL bearings vs the oversized ACL's goes, it will depend on your measurements that you will take on your particular crank using a micrometer. You will then need to measure the main bearing bores with standard size bearings installed and the entire cradle torqued to spec. This is measured with a good dial bore gauge and cross checked using your micrometers. Odds are if your block has never had material taken off the main bore, you will likely be using the standard sized bearings. Subtract the mic'd diameter of your crank journals from this value to obtain your clearance and go from there. Your parts list is ok for your power goals, but if I may suggest that you use your oem 88mm crank over the manley forged crank. The oem crank is historically more reliable than the manley forged crank and handles more power (ironically), but I think you will be ok to use the manley H beam rods as long as you keep it under 550hp. The FP Black with the SS housing will spool slower, but your rods will thank you as it's easier to control the torque with that thing.
Everyone is going to tell you something slightly differen as to what oil weight corresponds to what bearing clearances.
My main bearing clearances average 0.0026" and I use 10w30 VR1 synthetic. My rod bearing clearances are slightly looser than that. I tried 20w50 and found that I was making too much oil pressure for my turbo, but that's a different issue all together.
Old Oct 28, 2018 | 11:50 AM
stunna2o1's Avatar
I’m still pulling the old motor apart. Have to see if the crank is salvageable. Threw a rod and shot a hole the the motor and oil pan. Would you say even a turned oem crank over a brand new Manley crank? Was hoping might even just need a polish. From what I can see it might have only smacked where the rod broke in the center of the rod.
babaz7
34
Oct 13, 2017 04:57 PM
robin-evo6rs2
Oct 16, 2013 12:34 PM
MRfabolous
20
Sep 13, 2012 08:33 PM
craigybaby37
13
Sep 1, 2011 03:02 AM
LCS
11
Mar 14, 2010 05:47 PM
