Wastegate Actuators: Any Real World Results?
Old Dec 23, 2012 | 10:51 PM
  #31
blknblubkrdude's Avatar
My BBK-full is getting a rebuild as we speak... I have not spoke with my tuner yet, but from what I see 30ish psi will probably be the magic number. I ran 26psi on 91 octane all year long.
Old Dec 24, 2012 | 07:56 AM
  #32
BkzProblem's Avatar
Originally Posted by Freddie@Spec-Ops
Thats cool and all, but that negates the twin scroll dynamics of the stock turbo...
Freddie@Spec-Ops, are you talking about the wastegate/ dump from map? I'm interested in how it would affect the dynamics.
Old Dec 25, 2012 | 09:44 AM
  #33
sparky's Avatar
Edited
Old Dec 25, 2012 | 10:13 AM
  #34
sparky's Avatar
I figured that's where Freddie, was coming from back when he posted the reply. He apparently was refering to "non-divorced" , aftermarket gate/housings/dumps, that might reduce the inherent advantages of the dual-pulsed, Twin-Scroll turbine housing design.
Old Dec 25, 2012 | 12:56 PM
  #35
AreSTG's Avatar
i love when Sparky gets on WGA rants (page 2)
Old Dec 25, 2012 | 02:12 PM
  #36
sparky's Avatar
Merry Christmas everyone!
Old Dec 26, 2012 | 08:52 AM
  #37
Spec-Ops1's Avatar
Aight I couldn't bring myself to try out the Turbosmart WGA... went with a tried and true FP 25# WGA...
And yes, I was referring to the dump MAP makes with a turbosmart external gate where you need to wire or weld the flapper open which would negate the twin scroll effect...
Old Aug 20, 2013 | 02:36 PM
  #38
KOOLER's Avatar
So what's the best aftermarket universal wastegate actuator to use?
Old Aug 20, 2013 | 06:00 PM
  #39
sparky's Avatar
Personally, I like the Forced Performance, 18 PSI actuator. The older, diaphragm-style Forge actuator ain't bad either. I haven't tried the Turbosmart/MAP actuator although it looks like a nice bit of kit.
The FP has a sealed cannister so you cannot swap different rate springs. You either buy the 18 pounder, or the 25 pounder. On both the Forge and Turbosmart actuators you can disassemble the cannister and switch between different rate springs.
Old Mar 20, 2014 | 10:20 AM
  #40
Anyone else install the Turbosmart actuator? Might just go with the FP if no one has any results from the TS.
Old Apr 22, 2014 | 09:23 AM
  #41
Nimpoc's Avatar
This thread is such a tease...
- Stock, FP, Forge, Turbosmart, Kinugawa
- Anyone have before / after VD or at least SOP results?
EVO8LTW
30
Oct 29, 2018 03:17 AM
def1
Feb 2, 2017 10:34 AM
benIX
Feb 21, 2014 04:21 AM
alloutaudio
Feb 7, 2014 08:03 PM
eb66
Apr 28, 2010 07:01 AM
