View Poll Results: Which do you use and for what (primarily)?
Dynoflash and 1/4 mile
12
21.05%
Dynoflash and open track
13
22.81%
XEDE and 1/4 mile
7.02%
XEDE and open track
22
38.60%
Works (BrainFlash) and 1/4 mile
0%
Works (BrainFlash) and open track
10.53%
Voters: 57. You may not vote on this poll
Dynoflash or XEDE(XFlash) and for what purpose?
I'd like to get an idea of who uses what computer upgrade and what your primary use is for it. I get the feeling that the people that are using the Dynoflash are doing 1/4 mile racing, and the people that are using the XEDE/Works are using it more for open track type racing. I'd like to find out if this is actually true!
Interestingly - the vast majority of our client's have bone stock evos and never go to any tracks
The primary use for our flash is daily driving - adding 20 or so extra hp while smoothing out the power band and keeping stock like driveability and "feel"
I think a reflash is best suited to a user who wants a install it and forget it modification with zero headaches
While i do some drag race activity - that is more of a hobby of mine and a test bed for product R & D
Well to stay on topic Xede open track. Most of the flashers I know dont really 1/4 (occasionally) But use it for a kick butt streeter
On the reflash I may do the bigger injectors and pump, JUST in case I do the stage 2 lolrof
Originally posted by MP5
Hey Al back from the dead
It was nice you asked bout me
Originally posted by Eric Lyublinsky
Yes Even Bone stock this car with a Flash or Xede is alot of fun.
Eric
Eric
87+% of Vishnu customers are road race only
63+% of Dynioflash customers are impressed by Als 1320 success.
Nothing wrong with this how else would we of thought it would go Shivs a road racer and Al uses the 1/4 to show the potential of his products. When people see the info they say look see Im interested in having a low 12 sec EVO Ill go with Al cause he uses the same thing to go mid 11s. Or look Shiv just got back from Streets of Willow or look the Vishnu EVO stage 1 beat out a porsche 911 or a visnu stage 0 respectably held its own against 80K preped racecars driven my racing legends for 1500 bucks and a full day of different tests. These people opt for the flexability and adaptability of the Vishnu systems
I'd love to see a larger sample! Let's give it some time, but I suspect that this is eactly what we are going to see...
Absolutely! Well its panning out bout what I thought.
I think the poll should include options for those who just drive their cars on the street which are 99.99 % of my clients
The vast majority of the reflash users are either stock or just have a cat back exhuast and intake
These guys mostly use the car for day to day use and may hit a drag strip one or twice a year or maybe an aut x or two
99.99 % will never do a road race event on a track
BTW - for actual racers who do track days we have a very different tune which we offer which is vastly richer and has less timing to allow massive heat soaked abuse of a real track event
The Exede equiped cars I have seen ALL had lean a/f's which are not well suited to any road racing track days IMHO
I think that is silly - I bet 99.99% of the clients only drive on the street
You said that on your road racing maps (that you have) you run the car richer and take away more timing!
I would agree adding a little fuel to keep the cyl temps down would be a good idea but adjusting the ing table to add timing to burn the fuel will keep the ETG lower and keep the power up. By pulling timing and pulling fuel you’re just making the car slower with higher egts. Safe sure but why not then just run the stock settings with MBC to hold more boost to red line.
On pump gas timing is very important to keep up as high as you can (until Knock threshold/ or Octain limits are reach) and having the right amount of fuel to keep the cyl temps low is what makes a reliable, constant and repeatable power on a track car or a daily driver.
It's very easy to tune C16. You will not knock on it. You can't knock on race gas. You can run very high melting piston temps but not detonate on it. Detonation will destory a motor fast then high temps.
Eric
And it's spelled "XEDE" not "EXEDE", btw.
shiv
Originally posted by shiv@vishnu
Al, I'm tried of your BS. Watch where you tread.
shiv
shiv
I agree the merits of his dynoflash is fine no need to outright lie about another poduct when there is overwhelming proof and tons of independant AFR testing to prove otherwise
Bad form Al I really dont know whythey let you get away with slander all the time
I like to tune much richer about 11.0 / 1 than most other tuners
I think its a matter of not saying they are wrong to run leaner - just a difference of opinion
If Vishnu wants to post up some dyno sheets with a/f's showing that I am wrong then that would change my mind - but everything I have saw from them shows they are much closer to 12.0 / 1 - if i am wrong on that - why not just clarify my statement ? Why make threats?
