Walbro 400lph
Old Dec 14, 2012 | 08:29 AM
STIKiller4G63's Avatar
I am trying to get as close to 600 as possible....I have 6 an line from the feed but and planned on drilling out the siphon and thats it with this pump...so I should look into upgrading the return right?
Old Dec 14, 2012 | 08:39 AM
I am running a t67 on a build 2.3 btw...
Old Dec 14, 2012 | 08:59 AM
Ted B's Avatar
Assuming we are speaking of a -267 pump and E85 (?), you should upgrade the return to an AN -6, carefully drill the siphon, and upgrade the pump wiring.
If this is strictly a gasoline application, you may be able to get by with factory wiring and return line.
Old Dec 14, 2012 | 09:14 AM
Danm..ok...thanks...I will prob drill out siphon regardless and just buy 15ft of 5/16th fuel line and runn it as my return if I see my stock lines limiting the potential of the tune
Old Dec 14, 2012 | 01:33 PM
Mrauto50's Avatar
Talked to MAP today. They told me to drill the return. I'm going to try it. Great info here guys! Thanks!!
Old Dec 14, 2012 | 01:40 PM
mrfred's Avatar
Did they say to what diameter?
Old Dec 14, 2012 | 02:54 PM
Ted B's Avatar
I'd be careful with that. Drill the siphon too large and it will not function properly. As it cannot be purchased individually, there is no room for error.
Use a 9/64" bit as I specified in the link above. That has proven to control the pressure of two 255lph pumps running full time in parallel with a wiring upgrade, without creating siphoning problems. If there is still an issue, the factory return line should be upgraded.
Old Dec 14, 2012 | 03:41 PM
Mrauto50's Avatar
MAP didnt know what size. Referred me back to EVOm. Will do! Thanks so much!
Old Dec 19, 2012 | 09:10 AM
Mrauto50's Avatar
Ted help with drilling the return on the hanger. The pressure dropped to 60lb. I still need to install a 6an return line. Just ordered it. Thanks TED!!
mrfred
68
Jul 13, 2017 11:22 AM
Black_EVO_MR
Oct 30, 2016 07:18 AM
mrfred
58
Jan 4, 2016 06:09 PM
YFZracer32
Oct 19, 2015 12:03 PM
mrfred
39
May 16, 2012 03:28 AM
