Coolant tube
Old Dec 22, 2012 | 07:05 PM
carr16's Avatar
Coolant tube
Hi, I have a leak on the rear of the cylinder head. I've attached a photo of the pipe where the leak is. Have anyone repaired these before? Are they pressed into the head? Does the old one have to be drilled out?
Old Jan 14, 2013 | 01:46 AM
scrcco's Avatar
Evo 5/6?
It is pressed/bonded(some sort of adhesive) into the aluminum. You should be able to grab it with a sharp set of vise-grips and break it free.
Once you get it free you could tap that hole and put a threaded barb in its place. Thats a good time to eliminate the throttle body heating circuit.
evoniners
15
Mar 10, 2014 01:02 PM
riceball777
Aug 25, 2013 04:03 AM
fugiwara
Apr 4, 2013 07:45 PM
Duo Maxwell
Nov 16, 2012 11:26 AM
REDEVO1113
13
Nov 2, 2012 10:40 AM
