My build Thread Need Advises!
Old Dec 29, 2012 | 01:05 PM
triple L's Avatar
Hey EvoM
I'm in need of some opinions/advises on my 8 since i am unsure. Currently, i am building a 2.3l stroker and running a FP hta3582r for my setup and i am unsure if my fuel system will be enough for the power i want to make. I need some advise if my current fuel setup will be enough. I am debating if i want to stay with stock maf and ecu and/or if i should go mafless with speed density. Please see my mod list below and help me figure what else i will be needing:
-OEM 4g64 100mm crank
-Manley stroker 9.0:1 pistons standard bore
-Manley h-beam rods
-acl racing full bearing set
-arp main studs
-gsc balance shaft eliminate kit
-stock head
-272 kelford cams
-supertech single valve springs/ti retainers
-spoolinup cop
-gates racing blue timing belt
-gates water pump
-ported intake manifold
-65mm works TB
-1050cc fic bluemax injectors
-255 walbro un-modified
-dtm twin scroll manifold w/ dual tial 38m wastegates
-fp hta 3582r with 1.06ar twin scroll housing
-custom 3" dp
-3" full jic magic exhaust
-3.5" ebay cxracing fmic
-custom 2.5" licp
-injen uicp w/ intake
-evo9 crushed bov
My power goals will be 550awhp on a mustang dyno and strictly on e-85 possibly 30psi. The car will be used for occasional drags and will be driven about 3-4 times a week. Should i go with the Buschur Racing dual pump and bigger size injectors and go with speed density for a smoother tune or will the 255 wally and fic1050s hold up?? Any response will be greatly appreciated.
Old Dec 29, 2012 | 01:09 PM
tdt1805's Avatar
Buschur Double Pumper and some 2100 fic injectors and never worry about it again. Buy it right the first time/overpowered and never buy again or waste money in spending more and more to upgrade. Speed Density will get you a little more power also. Im considering going to it and I just have a filter right now...lol
Old Dec 29, 2012 | 01:22 PM
dlucasevo8's Avatar
man i cant wait til i have ennough $ for a full build.. right now just shootin for a 500hp dd
Old Dec 29, 2012 | 01:24 PM
dlucasevo8's Avatar
i got a 340pump and 1000cc precision injectors ams fuel rail
Old Dec 29, 2012 | 03:45 PM
triple L's Avatar
is the pump new?
Old Dec 29, 2012 | 09:10 PM
spadednick88's Avatar
Ur fuel systen isnt big enough for ur goal. Remember that e85 requires 30% more fuel. I was on 1650's and hit 80% duty cycle at 620 whp
Old Dec 29, 2012 | 11:36 PM
triple L's Avatar
it's actually not that expensive to the the build though i will be doing it myself with help of friend and cousin... here are the list of parts and how much i paid for:
-oem 4g64 100mm crank(polished) - $225 off here on evom
-manley 9.0:1 stroker pistons
-manley h-beam rods
-acl racing full bearing kit
-arp main studs
-cometic mls headgasket - $1136 off ebay whole kit
-gsc balance shaft eliminate kit - $170 off ebay
in total i spend around $1500 and i just bought them piece by piece once i've saved up...
i will be taking the block and head to get it decked out and resurfaced to secure any leakage and probly hot tanked the block and re-hone
Old Dec 29, 2012 | 11:38 PM
triple L's Avatar
i will look into getting the buschur double pumper and fic 2100 once i have enough saved up... damn those 2100 aint cheap
Old Dec 30, 2012 | 10:03 AM
Ya i went with id 2000's. They hit the bank pretty hard
tscompusa
Jun 15, 2016 06:43 AM
triple L
For Sale - Cars For Sale
17
Dec 24, 2015 08:45 AM
bigdnno98
30
Sep 15, 2014 07:53 PM
triple L
Apr 17, 2014 12:28 AM
Creamo3
Jun 1, 2009 10:21 PM
