Evo 8 with MAP EF2.5
Old Jul 7, 2013 | 02:09 PM
  #151
evotuner04's Avatar
15 Year MemberLikedLoved
Well did a retune on car and came back exact same results. Dont know why disgustedpatedm3s turbos spools so much quicker. Only thing i can try is more preload but thats going to come down the road since work is consuming my life now.
Old Jul 7, 2013 | 03:07 PM
  #152
sparky's Avatar
Originally Posted by evotuner04
.....Dont know why disgustedpatedm3s turbos spools so much quicker. Only thing i can try is more preload.....
Preload should be at least 23-24# for your 31# peak boost level. That's a minimum preload level for a 30+ PSI peak, IMO. A lot of it depends on what rate spring is in the WGA and whether or not the peak boost is flatlining, or looking to creep. If it don't have a tendency to creep or overshoot the peak level then I'd preload it up to 27-28#.
You'll need to work up to it cautiously in 2# increments, but if you preload it to 27# It'll spool like a bat outta hell. You have the MAP/Turbosmart actuator fitted with the HD spring dont you? Refresh my memory: Are you using an MBC?
Old Oct 5, 2013 | 12:51 PM
  #153
evotuner04's Avatar
Little update here:
Just bought a MAP 2.3 to pair up with the EF2.5 so we'll see how she spools now
Old Apr 17, 2015 | 11:50 AM
  #154
6spdlegend's Avatar
bump- interesting in parin this EF2.5 with my full bolt on stock block- do you guys think there are better stock frame turbo options out there for us now?
evotuner04
For Sale - Part Outs
13
Dec 2, 2016 10:09 AM
evotuner04
For Sale - Cars For Sale
36
Oct 20, 2016 11:36 AM
evotuner04
31
Nov 15, 2015 06:18 PM
evotuner04
13
Jul 26, 2015 02:59 PM
