Evo 8 with MAP EF2.5
Old Mar 27, 2013 | 02:48 PM
  #106
evotuner04's Avatar
15 Year MemberLikedLoved
Heres my EF3 graph with no boost leak a year ago
Old Mar 28, 2013 | 04:32 AM
  #107
mean4g63's Avatar
Originally Posted by evotuner04
I'm going to do a virtual dyno run starting at 2500rpm pretty soon here to see if it helps shift the power curve left, im not sure if tuner starts his runs slowly at 2500 instead of going all out. The dyno could be loaded differently too because i looked at my stock evo 8 turbo graph and it spooled just a little earlier than this turbo and we all know a stock turbo spools stupid fast
evo 8 turbo spools just a little faster? wow. Talk about a serious issue. My 7 turbo with 10.5 hotside hits 30 psi by 3500 RPM.
You know I could send you a 390 ish WHP stock turbo VD log vs your EF2.5 and we could do a comparison between the two. Not to mention it would be interesting for everyone to see it as we are both non-mivec and fairly similar mods. What you think? send me your email via PM and we can do this and you can post it.
JDM Evo 7 RS
Map 02 eliminator recirculating downpipe
AMS 3" exhaust and decat
GSC S1 cams
Synapse DV
STM lightweight front brake rotors(with my custom brackets and larger Superlite calipers)
MAP Rev 3 intake
FP 70MM TB
ETS 3.8" garret core intercooler with upper/lower piping kit
Carbing cold air box with 3" intake and Blitz SUS steel mesh filter
stock turbo with 10.5 hotside (aka evo 8.5 turbo)
JDM pump gas 28psi falling to 24-25psi
Old Mar 28, 2013 | 05:58 AM
  #108
sparky's Avatar
I'd like to clarify a couple of things. In my first reponse it might have seemed that I was ragging on your tuner. But, I was not. He is performing his job of tuning your car on the Dyno. In fact, he achieved some altogether impressive peak torque and horsepower numbers.
Your MAP 2.5 turbo is a one off configuration. This is the first time, ever, tuning one of these puppies. Therefore, being a first time endeavor, there are no preexisting base tunes, and no established data on how to tune one of these units yet. The relatively slow spool and the late torgue hit are not your tuners fault. These two issues preexist and are independent of the tuning process.
Your tuner works with the car as set up the way it is when you drive it up onto the rollers. He just tickles the keyboard and adjusts the tables, etc. Sure, up to a certain extent he can impact turbo spool by playing with the fuel and timing tables and the WGDC. However, it is your responsibility to deliver the car to the tuner with wastegate preload properly set to at least 24-26# for your particular 31# target boost level. Also, I am thinking that the HD 24# spring should have been installed instead of the weaker 16-18# internal spring prior to the tuning session. Likewise, your DV probably needed crushing as well if it is still uncrushed.
Old Mar 28, 2013 | 07:02 AM
  #109
Craig King's Avatar
Bottom line, did you test the EF3 at the same pressure and condition as EF2? If so, what was the difference in peak power?
Old Mar 28, 2013 | 08:43 AM
  #110
sparky's Avatar
That's very true, Craig King. Peak boost levels need to be same on both turbos, just as the actuator spring pressure needs to be set to the same tension using the same actuator, etc. For the comparison to be accurate....All variables need to be constant and identical.
Old Mar 28, 2013 | 10:24 AM
  #111
Craig King's Avatar
I'm not trying to start an argument or $hittin' match.... I'm sure we all believe that the EF2.5 spools faster than the EF3, but I'm curious how much LESS power the 2.5 makes from the 3.
Old Mar 28, 2013 | 02:44 PM
  #112
sparky's Avatar
....I'm ditching the EF3 in hopes of having a lot better spool and just as good up top with this new turbo..... I absolutely love the EF3 but on a stock 2.0 it wasnt quite for me (full spool was around 4400) It has just nasty power up top. But I personally like quick nasty torque....
This is basically the same reason that I ditched my JB Red. Originally, I had wanted to trade down to a a BB Green, or a BB BBK-Full in search of quicker spool and better transient response. I was fully willing to sacrifice some peak horsepower in exchange for quicker response given my stock 2L motor.
As it turns out, I got a great deal from Chad on a used BB BBK-B. I just could not afford the tariff for a new BB-Full, or BB Green. At the time that I pulled the trigger, MAP had not yet configured their EF 2.5, or I definitely would have considered it as well. So, I too am following this thread with interest.
Old Mar 28, 2013 | 05:01 PM
  #113
evotuner04's Avatar
JDM Evo 7 RS
GSC S1 cams
Synapse DV
MAP Rev 3 intake
FP 70MM TB
Will do sir, it wont be til this weekend when i get some more time
Map has told me all wg are properly preloaded, also after turbo was already in i asked my tuner to check wg preload because i didnt want that to be a problem. (car was in for a clutch about a month before tune, never touched it, asked him again before tune, nothing.) another note map has told me it shouldnt matter what spring is in the actuator considering its just known as a safety to the turbo and ebc will dictate what the boost is at. all the things you guys have brought up are items ive thought of and discussed with map/tuner. Idk if some ppl are just trying to avoid having to do more work and pushing aside hoping i do it myself later on? all i know is if this is the cause of laggy boost i'm going to be a rather pissed off guy. I spent a lot of time and money getting this setup together and making sure i wasnt missing anything. If i wouldve known for one second that this wg is causing problems i wouldve pulled off myself. we will find out soon when disgustipatedm3's results are in. until then im waiting. theres also the thought of my old evo 8 turbo spooling a few 100rpms sooner than this turbo has me wondering is it his dyno?what else would cause that turbo to be at 20psi at 4000rpm? is it my cams? idk i just want to figure it out
PS: BOV is crushed
No sir
Old Mar 28, 2013 | 05:11 PM
  #114
evotuner04's Avatar
Stock evo 8 turbo 10.5 hotside
Old Mar 28, 2013 | 07:31 PM
  #115
sparky's Avatar
[QUOTE=evotuner04;10733405]...Map has told me all wg are properly preloaded, also after turbo was already in i asked my tuner to check wg preload ...never touched it, asked him again before tune, nothing.) another note map has told me it shouldnt matter what spring is in the actuator considering its just known as a safety to the turbo and ebc will dictate....
IMO, Your tuner and MAP are both being a wee bit silly:
1) " All wastegates are properly preloaded...." -Huh?
2) " It shouldn't matter what spring is in the actuator" - I love this one.
3) "...the EBC will dictate what the boost is at..." -Yeah, sure, whatever
The above generalizations are merely ad hoc rationalizations that do nothing to solve, or explain your slow boost issue. If , as stated, your EBC alone dictates where boost is at under all conditions, then your slow boost issue should be fixable simply through EBC adjustment or reprogramming of that control device.
Old Mar 29, 2013 | 07:08 PM
  #116
mean4g63's Avatar
your car definitely had more lag on evo 8 turbo than normal.
Old Mar 30, 2013 | 09:50 AM
  #117
evotuner04's Avatar
Yeah no kidding so is it a cam related issue? Kelfords I heard are very laggy cams.
Old Mar 30, 2013 | 07:52 PM
  #118
sparky's Avatar
You know what I really like about your dyno numbers? It's that torque figure. The 407 lb-ft obtained on a Mustang Dyno is impressive. Once you get that slow spool issue solved, then the torque should improve even more. That speaks gobs about the power potential of that new EF 2.5 turbo. I can't wait to see what she is capable of accomplishing powerwise once you get her spooling properly. I am willing to bet that there is still more left on the table torquewise.
Old Mar 30, 2013 | 09:31 PM
  #119
mean4g63's Avatar
You know what I really like about your numbers? It's that torque number. The 407 lb-ft obtained on a Mustang Dyno is impressive. Once you get the slow spool issue solved, then the torque should improve even more. That speaks gobs about the power potential of that new EF 2.5 turbo. Can't wait to see what she is capable of once you get her spooling properly.
+1. I have always preferred the TD06 65mm turbine wheel. Always makes nice torque numbers.
Old Mar 31, 2013 | 11:15 AM
  #120
evotuner04's Avatar
Spun through 1st and 2nd last night, although it is cold in MN thats still fun as hell
