popping out of 5 gear
Old Jan 8, 2013 | 07:53 AM
blowngasket's Avatar
there is a Detent Ring on the syncro that the slider fits over aswell that could be worn or the slider could be jacked up gotta pull it aprt to see.. soo do the easy stuff first, also could be a shift fork issue. Id pull the oil plug and check fluid, see what it looks like, try to flush it and start with new fluid see what happens. When my Trans was slipping out of gear it was, the shift forks being seriously worn by lack of lube from a busted seal on the Expressway, but also my 5th gear Bearing blew apart. it still shifted good, but i replaced everything moving in that trans.
Old Jan 11, 2013 | 04:36 AM
curleymerkin14's Avatar
Replaced fluid with new Mitsubishi oil car is like new
spgtfr
11
Jan 14, 2016 07:15 AM
Btaylor36
Lancer Tranny/Drivetrain Tech
Aug 27, 2015 06:03 PM
gkew
Jul 27, 2013 08:22 AM
CMcraz23
Mar 3, 2008 03:49 PM
Sicktght311
Lancer Aftermarket Forced Induction Tech
34
Jun 21, 2006 06:56 AM
