Lifter tap or Rod knock??? (Video inside)
Old Jan 8, 2013 | 02:31 AM
MRadjahoe's Avatar
Hey guys, I was running the car the other day and noticed the oil low and I started hearing a tapping noise while driving... Parked the car and changed the oil (10w30) this is what happens when the oil is fully warmed up. If I drive the car as soon as the coolant is warm, you don't hear anything. When warm... Check out the video. ...you don't hear it under boost of course.
Old Jan 8, 2013 | 03:12 AM
jameelrose's Avatar
Definitely a lifter.
Old Jan 8, 2013 | 03:14 AM
MRadjahoe's Avatar
Should I take them out and clean them?
Old Jan 8, 2013 | 04:22 AM
evoxsi's Avatar
ive had the same noise for almost 1.5 years. i replaces lifters, cleaned the rocker arms/holes and it never made a difference. hope u find that cause cause i havent been able too.
Old Jan 8, 2013 | 04:24 AM
MRadjahoe's Avatar
Cool. I'm looking at getting some topline lifters and replacing them soon. This started happening after a 272 cam install and 5000 mile oil (e85) shame on me!
Old Jan 8, 2013 | 04:49 AM
evoxsi's Avatar
thats what lifters i put in
Old Jan 8, 2013 | 04:50 AM
MRadjahoe's Avatar
Cool thanks.
Old Jan 8, 2013 | 01:20 PM
4g63evoeight's Avatar
Pop the valve cover off and put some tension on each rocker arm and see which one has some play in it, that will tell you which lifter may be collapsed. deffinatley not a bearing
Old Jan 9, 2013 | 01:25 AM
Jeff11r34's Avatar
ive got the same problem didnt do it when i first got the car ive only had it 8 months
Old Feb 6, 2013 | 01:04 PM
MRadjahoe's Avatar
Replaced lifters. No more tick!
Old Feb 7, 2013 | 10:10 AM
EvoRinga's Avatar
Bleed the lifters properly.. I had a similar noise before I switched my hks 272s for s2s
Old Feb 9, 2013 | 06:04 AM
sparky's Avatar
What are the ambient air temps where you live? If the lifters were not properly bled when you did a cam change, then you have a ruptured lifter. I have live with a ruptured lifter for years. FWIW, I have found that running Mobil1 0W-40 motor oil eliminates the ticking sound on my motor though.
Old Feb 9, 2013 | 06:07 AM
MRadjahoe's Avatar
Originally Posted by sparky
Whar are the ambient air temps where you live? If the lifters werent properly bled when you did a cam cahange, then you have s ruptured lifter. I have livedvwith a ruptured lifter for years. I found that Mobil1 0W-40 motor oil eliminates thev
ticking sound on my motor though mm
I replaced the lifters guys.... No more ticking sound for me.
Luan Nguyen
Oct 30, 2016 03:26 PM
Chrispy0530
Sep 20, 2016 06:19 AM
johentie
40
Jul 15, 2016 06:02 PM
AutoEuphoria
Apr 23, 2016 08:11 PM
OL_DIRTY
May 19, 2015 09:04 PM
