Grindy 2nd and 3rd
Old Jan 8, 2013 | 04:00 AM
thebigp11's Avatar
Grindy 2nd and 3rd
Hey everyone lately iv been having a grindy 2nd and 3rd gear and i cant find out wat the problem is. Iv changed the master and slave cylinder both brand new oem, changed the clutch disk and had the rest inspected and they said nothing was wrong with the clutch. The retractor pill was removed, there are no leaks, the clutch pedal was adjusted and the line was bleed about 6 times but what make me think its not the tranny is when i pump the clutch about 5 times the shift is smooth but when i stop and shift again its grindy. And when i down shift theres nothing wrong. Can someone pleassssseee help me i hate this so much and need to fix it and im all out of ideas and im trying not to spend the money to pull the tranny and find out its not the problem. If anyone has any ideas or experienced this your help would be greatly appreciated
Old Jan 8, 2013 | 04:17 AM
foxbat's Avatar
The clutch won't cause a gear-specific grind, it's likely the sync rings.
Old Jan 8, 2013 | 01:53 PM
thebigp11's Avatar
Damn
Old Jan 8, 2013 | 02:22 PM
foxbat's Avatar
If I had a penny for every time someone damages a sync ring.... it's common Evo issue, people drive em hard! I have a grindy 5th, already bought the sync ring & waiting for my clutch to wear out to replace both at the same time.
Old Jan 8, 2013 | 05:50 PM
thebigp11's Avatar
well how bad is it to continue driving it? i dont really beat on my evo maybe once a month but, it shifts fine at higher rpms, its just when i shift around 3-4000 rpms.
Old Jan 8, 2013 | 06:05 PM
Frew's Avatar
My tranny is trashed, 2nd, 3rd, and fifth. Try different shifting styles, slow roll into the gear, try different rpm, etc. I drive mine everyday and never grind it, if someone else drove my car I bet they would grind like crazy.
Old Jan 8, 2013 | 06:17 PM
foxbat's Avatar
It's just a 'forum' diagnoses, but a good mechanic should be able to confirm the cause within a minute, I mentioned sync rings because it's 90% the cause of gear specific-grind & it's very common. I don't recommend driving with damaged sync rings for a long time, because they could also damage shift sleeves & they are even more expensive than sync rings.
Old Jan 8, 2013 | 07:26 PM
llDemonll's Avatar
it's not the parts that are terribly expensive, it's the labor
Old Jan 9, 2013 | 01:22 AM
Jeff11r34's Avatar
my evo 8 grinds going into 3rd sometimes and 5th most times and reverse once in awhile. Ive been told Syncros. havent looked to much into it the thought of syncros scare me. Its parked for the winter soon ill be sending it to get ripped into.
Old Jan 9, 2013 | 03:59 AM
thebigp11's Avatar
Yea i was looking at the rings i googled them and found that jacks transmissions website and he has the rings for 72 bucks and i have a 1 year warranty on the tranny that ends in april IF the guy wants to honor it..... Its been having problems with it since day 1 and when i bring it up it always gets pushed to the side of the conversation. At this point i really just want to sell my evo.
Old Jan 9, 2013 | 08:13 AM
llDemonll's Avatar
get a lawyer and get your **** fixed
austin_davee
Dec 29, 2016 08:51 AM
sUp3rSiMpLiCiTy
Oct 14, 2015 01:17 PM
monkey_187
38
Feb 27, 2009 03:54 PM
AK805
Lancer Tranny/Drivetrain Tech
21
Jul 24, 2007 11:14 PM
quantum
Oct 5, 2004 05:48 AM
