Injectos or Fuel Pump or Both for 350whp
Old Jan 11, 2013 | 04:44 AM
foxbat's Avatar
Originally Posted by silverevo05
Less is more for me and despite the "you will want more later on" I know I would be happy with about 350whp, heck I'm happy now. I drive a manual 06 scion xb so that should explain some.
Water/meth I would like to avoid. Nothing wrong with it just that there is more to go wrong
In regards to fuel pump I can't stand the whine of the walbro. I know many say they don't have it but I have seen and heard others that do
Any fuel pumps other than walbro to suggest? also i think I would like to go with rc 1000 IF i have to go that route
-Water/meth: you could go for dual, switchable maps 1st for 91 & 2nd is 91+water/meth.
-As mentioned, DW301 pump is even better than the walbro
-RC 1000 are good choice, easy to scale/calibrate
Old Jan 14, 2013 | 09:29 AM
silverevo05's Avatar
I KNOw 350 whp is the border for stock vs modified pump and injectors but i wanted to know which is first to modify.....
Pump is 160$ for the DW and 360$ for injectors plus having to get tuned.
..Big difference in price so i would like to avoid injectors or keep stock around 80% duty cycle
Old Jan 14, 2013 | 10:18 AM
foxbat's Avatar
You could go for 22-23psi boost with stock injectors.
Old Jan 14, 2013 | 11:47 AM
BEKevo's Avatar
For what it's worth i make 333whp/303wtq (mods in sig) using 91oct on a dynojet.. This is at 94% idc. I plan on cranking the boost up also once I get an Omni 4 bar map sensor, for logging purposes.
---Keep in mind, if your using Evoscan for logging, it's been reported that ~125% idc is the true 100% margin for injectors.. I've seen, from credible members, safely using 110% idc for extended periods with no consequences. I plan on doing the same..
Old Jan 14, 2013 | 06:40 PM
^ i 've been reading that aswell about evoscan and 20%
I would like to stay around 80% and avoid injectors at this time if possible
good info...anyone else
Old Jan 14, 2013 | 07:47 PM
Raptord's Avatar
No way you'll be at 80% IDC in evoscan and make 350whp.
Old Jan 14, 2013 | 08:04 PM
^ no that's ok....around what (I understand this is a ballpark) whp would I be?
Thanks
Old Jan 14, 2013 | 10:45 PM
BEKevo's Avatar
So you want 350whp and 80 % idc in EVOscan on the stock injectors? There's no way you'll be able to achieve that on stock injectors w/ any fuel pump, you'll need to upgrade the injectors.
Old Jan 14, 2013 | 11:14 PM
^ thanks, but thats why I was saying it's ok and around what hp would I be seeing at 80 - 90 % IDC....I have now learned if i would like 350whp I need injectors
Thanks
Old Jan 14, 2013 | 11:21 PM
mrfred's Avatar
Don't think you're going to get to 350 whp with bolt-ons and 91 octane, at least not with a safe tune. Suggest that you start with the pump, and if you run out of injector, then do the injectors.
Old Jan 15, 2013 | 04:38 PM
RMDZidane's Avatar
Hello silverevo. You seem to have pretty conservative goals, and reliability is one of them I take it. I would get a Denso 'Supra' fuel pump. One can't beat OEM reliability. Though I doubt you'll get to 350whp more than once with the mods you listed
Old Jan 15, 2013 | 04:42 PM
Thanks RMD
I actually though about that but I believe it doesnt fit in the stock housing. I believe I will settle on the DW and see how far I go with that and stock injectors then save up and get the rc 1000... They seem to be easier to scale for tuners with all the info out on them
Randal
Sep 22, 2013 09:57 AM
evolutionaryevo
10
Jul 27, 2013 07:25 PM
Tuor
11
Jan 2, 2012 10:20 AM
victim619
Dec 21, 2010 12:10 AM
jxs1984
131
Oct 1, 2009 09:04 PM
