Cam Installation - Installation Prices?
Old Feb 11, 2004 | 08:18 PM
ItsStockOfficer's Avatar
Originally posted by Z1 Performance
actually it depends how it is done...there is a right way, and a cheesy way. Riht way is about 9-11 hours depending who is doing it, and the cheesy way is about 4 hours. It's not worth the risk of snapping a cam (seen it happen MANY times) or getting something else wrong (ie not replacing timing belt) IMHO.
Umm, your right way is 3-4 hours and your wrong way is 1-2....
I have done it the "wrong" way about a dozen times, why does it make it more likely to snap a cam. the belt tension is identical to how it was previously. The only possible way a cam can snap if it siezes, and the only way that can happen is if assembly ludbe is not used(prolly doesn't matter neways), A bearing cap is over torqued(also prolly doesn;t matter to much, although Im carefull not to do it) or the wrong cap goes on the wrong spot(most likely)
NONE of those things have to do with the method of how you change it
Why do the cams are if the belt was changed?
Old Feb 11, 2004 | 08:22 PM
BadBoyBeltran's Avatar
If the belt was like at least a year old, id PROBABLY change the belt, but it hasnt even been a year yet since the evo came out.
The current belt should be fine. 3-4 hours should be it.
Old Feb 11, 2004 | 09:04 PM
TRDHarrier's Avatar
well, Adam, how much do you charge for installation with the cams? I wanna get them but wanna see how much I need to save first.
Old Feb 11, 2004 | 09:08 PM
boostedwrx's Avatar
holy christ it should take 2 hours. 3 if he takes the whole belt off.
Old Feb 12, 2004 | 05:41 AM
DARKMETHOD's Avatar
man we just pulled a hi-jack on this thread. i'll pm you on a meet.
i would say timed is nothing, getting it right the first time even with a little percaution is everything. see i'd rather do the timing in 3-6 hours rather then rush it. but that's just me. man but i would deffinetly try to get some money back. 'cause if i paid 300 bucks for something you bet i'll go back if it's not right.
