Wiseco 2013 Piston Releases
Old Jan 24, 2013 | 08:48 PM
mrboost05's Avatar
I tried to get a set of thease two weeks ago and all 3 of the dealers said that the part number i gave them was incorrect nice to see they released them i love all the choices we have.
Old Jan 24, 2013 | 09:17 PM
17pstockcar's Avatar
Thanks for the info guys
Old Jan 28, 2013 | 04:37 PM
JohnBradley's Avatar
Old Jan 28, 2013 | 04:41 PM
Here are some updated pics of the new HD2 piston. Mrboost05, the part numbers are good but they are still technically prelease and not available.
Old Jan 28, 2013 | 05:53 PM
Gordian79's Avatar
Are the gas ports vertical?
Old Jan 28, 2013 | 05:59 PM
Forgot to ask for the production stuff. These I ordered without gas ports, Jeff's methanol pistons are vertical.
Old Jan 28, 2013 | 06:00 PM
ronshearer's Avatar
The shelf stock HD2 parts will have 8 lateral gas ports.
Old Jan 28, 2013 | 07:18 PM
Gordian79's Avatar
Good to know.I might try these on my drag car.These are shelf pistons correct?The ones i currently have arent and its a pain to get replacements if i needed to.
Old Jan 28, 2013 | 10:27 PM
FL_SilverEvo8's Avatar
I have a question about these pistons. I see they aren't making 10:1 comp any more. Well not on the shelf. But they do have 10.5:1. Is that a big jump for comp ratio's? I am build a 2.0 and I will be running e85 most of the time. But in case I am not around a e85 pump I will witch over to 93. (We only have one e85 pump here where I live) Just wondering if I should go with 10.5:1 or 9:1. Or just go with a different brand all together that has 10:1 on the shelf?
Old Jan 30, 2013 | 01:11 PM
I prefer to run 9:1 motors myself anyway, but if you want a 10:1 motor that technically would be a custom piston. Since they spec the pistons out with a 0.042 gasket (stock) and most of us run a 0.051, there is a drop in compression anyway. 10:1 motors are limited to 20-21psi for the most part anyway from what I have seen...safely on 92.
Old Jan 31, 2013 | 07:56 AM
9:1 on e85? Wouldn't I be better with 10.5:1 on e85? I am bearly going to be running 93. And from what I hear it's all about the tuner.
Old Jan 31, 2013 | 11:16 AM
10.5:1 doesnt seem to add as much as the potential headache. If we can run 8.30 at 170+ running a 9:1 motor I am pretty sure it will work We are switching to methanol and higher compression this year but thats another story.
Old Mar 3, 2013 | 01:09 PM
mrboost05's Avatar
can anyone give me the part number for a wesico hd piston for a 2.3 motor in 85.5mm just so happens the 10.5.1 pistons i orderd were for a stock crank not sure how they messed that up and i dont wanna order the wrong stuff again i will take a compression of 9.1 -10.5.1 i wanted to try higher compression but i will not be picky thanks guys.
Old Mar 3, 2013 | 05:52 PM
dcshoeco16's Avatar
MrBoost- according to the new part numbers the pistons you are looking for are K667M855 for a 9.5:1CR or if you plan to be on e85 the 10.5:1CR Pistons are K668M855
Old Mar 4, 2013 | 06:51 AM
mrboost05's Avatar
thanks for the help never try to look up part numbers from your phone
