Nitrous to spool turbo?
i believe its because nitrous makes more hp thru more fuel and air in the combustion chamber. this increases the exhaust gasses thus pushing more exhaust into the turbo compressor
Hmm, I have always thought of it in a different way. When nitrous is used to spool a turbo it is used in the lower band of rpms because nitrous adds a ton of torque down low cause your engine to rev much quicker and with a lot more torque causing the you to get into the rpm range of the turbo much quicker, after the turbo is spooled most stop the flow of nitrous.
Jason
Jason
youre typically not supposed to run it below like 2500-3000rpms, but if youre in first gear and at WOT (as most nitrous systems make you do before it arms) your engine is acclerating very quickly and will not do as much damage as say 3rd gear at 2000rpms
I believe this is on a NA motor and one that is not built because of all the torque it can make down low. If you need nitrous to spool your turbo chances are you are running a ton of boost and a ton of power on a very built motor, hence the nitrous will not cause damage.
This is becoming popular in the UK. As we are not all after huge power figures, we use the N2O in the lower segment of the rev range (2000 to 4500rpm) to make the engine produce more torque (and therefore more exhaust gas) to spin the turbo up earlier. A lot of the kits here enable you to graduate the flow of the N2O and because your only using small amount (25-50bhp) you can use it quite early. Basically you feather the N2O in (between say 2000-2500rpm) and then when the turbo is at full boost (much earlier than without) feather it back out (say 4000-4500rpms). I suppose you could have a system that is boost dependent. Have the system trigger at around 2500rpm and then turn off when the boost is full.
Spooling the car with N2O wont be of an advantage until you are using one hell of a monster turbo. I have not seen an evo turbo kit that would be big enough make full advantage of this. So unless you are looking at a built motor and a custom turbo setup I would just leave this to the pro drag racers.
BadBoyBeltran is right. Get yourself a Motec standalone ECU (or any that offers anti-lag) and you will be well away. The problem with Anti-lag is that it will shorten the life of your turbo. Or you could get a strocker kit and run it at high comp. ratio. This will help the off boost performance and make the turbo spool up much quicker. Higher comp. dose mean a lower top end performance though. Its all a compromise!
blackevo110
15
Jul 18, 2007 11:49 AM
Swift Drift 14
Lancer Aftermarket Forced Induction Tech
21
Nov 13, 2005 10:10 PM
2.3EVO8
Aug 7, 2005 02:18 AM
