Installing back to the OEM boost controller
Old Jan 27, 2013 | 07:07 PM
Czarcasm's Avatar
Recently I acquired a grimmspeed ebc, installed it and got bad idle, wanted to dd the car til the dyno time in 3 weeks. I knew this would happen but not this bad of a idle. Hooked up the OE controller, does it matter how you hook up the vacuum lines? When I took it off I never paid attention where the vacuum lines go until the ebc install.
Old Jan 27, 2013 | 07:17 PM
tdt1805's Avatar
Look on the hood of engine. It shows you the vacuum points and everything. That's what i used.
Old Jan 27, 2013 | 08:22 PM
Czarcasm's Avatar
Different hood installed. Tried that
Old Jan 27, 2013 | 08:27 PM
sktng22's Avatar
https://www.evolutionm.net/forums/ev...m-diagram.html
Old Jan 27, 2013 | 09:33 PM
Czarcasm's Avatar
Thanks
Old Jan 28, 2013 | 06:21 AM
heel2toe's Avatar
FYI your idle shouldnt be affected by installing the solenoid. If you are just putting around the solenoid isnt really doing anything. I would recheck how you have your vacuum lines hooked up as well as make sure you dont have any vacuum/ boost leaks.
FrenziedTom
Apr 25, 2016 07:32 PM
TS Dork
Nov 28, 2013 07:34 PM
Inline_X
Jul 19, 2012 03:36 PM
JohnBradley
Lancer Troubleshooting
Jul 2, 2008 11:41 PM
[Cyanide]
Aug 12, 2004 10:21 PM
