Manual Boost Controller Install Help!
Old Aug 12, 2004 | 01:40 PM
[Cyanide]'s Avatar
I have my MBC hooked up straight to the wastegate actuator & the turbo outlet.
IMO this is the best way to do it, it's worked on my MR2.
I have the one vacuum line that was tee'ed that USED to go from the boost solenoid to the wastegate actuator & turbo outlet PLUGGED.
But I still have the intake vacuum hose connected to my AEM Short Ram Intake. Is this wrong? Should I plug the intake side hose also? Or should I remove the boost solenoid completely?
When I rev it in neutral, it seems to build 5psi or so in neutral!
Old Aug 12, 2004 | 02:36 PM
[Cyanide]'s Avatar
Never mind, figured it out.
Old Aug 12, 2004 | 02:46 PM
alex_alex's Avatar
what was the problem?
Old Aug 12, 2004 | 04:48 PM
[Cyanide]'s Avatar
Well everything is connected properly, it holds 20psi to redline no problem.
But the problem now is...
I can sit in neutral, rev, and build 10psi of boost.
In neutral.
Old Aug 12, 2004 | 07:32 PM
alex_alex's Avatar
thats a bit strange, it shouldn't go past 0. sounds like your boost gauge may be hooked up in the wrong place. How did you connect it?
Old Aug 12, 2004 | 10:21 PM
[Cyanide]'s Avatar
Actually the boost gauge isn't the problem since it worked fine prior to the MBC install. It would never go past zero.
So, *shrug*.
insanum
Nov 11, 2023 05:16 AM
drb
53
Oct 25, 2016 07:50 AM
WhiteHat
Mar 24, 2016 01:25 PM
_Ryan_
May 16, 2015 10:01 AM
brusinn
10
Sep 3, 2013 05:53 AM
