Is 18 psi stock on a EVO 7?
Old Jan 31, 2013 | 01:29 AM
Benji Van Eerte's Avatar
I have a jap import evo 7 that I was told is stock.
I ran it on a Dyno recently and got 163kw/222hp at the wheels. I also had a average of 18 psi and a spike of 20 psi.
Are these stock numbers and are they normal for Evo 7 that's 12 years old.?
Maybe it's a ECU tune change, but I'd like to know if it's normal.
Old Jan 31, 2013 | 02:22 AM
foxbat's Avatar
Stock boost is 18psi, it's likely to tapper down to 16psi by red line.
It would be a good idea to examine the wastegate.
Check for boost leaks & measure engine compression.
What's the mileage on the car?
Old Jan 31, 2013 | 02:27 AM
I checked the Compression around 3-4 months ago when I purchased the vehicle.
It's currently got 150,000 km's on the clock.. I know it's alot compared to others, but I am restoring it as best I can. Services/replacing everything before modifying for power.
17pstockcar's Avatar
Yip that sounds about right, maybe a little low from the normal but not by much
Old Jan 31, 2013 | 03:43 AM
foxbat's Avatar
Install a new fuel pump (ex. walbro 255).
Old Jan 31, 2013 | 04:47 AM
EvolutionRR's Avatar
18 psi is stock for evo's
Old Jan 31, 2013 | 11:10 AM
I actually have another thread about just that! sadly, no-one has been able to give me any help yet.
I purchased a Walbro 400 because I have plans to go further then the Walbro 25 can take me. Just unsure if it's so overkill it could do damage..... LHP vs it's PSI ****...
Please read, comment and save me! haha
https://www.evolutionm.net/forums/ev...l#post10636163
Old Jan 31, 2013 | 02:17 PM
foxbat's Avatar
255 & 400 are max capacity numbers (400 liter per hour) having a bigger capacity pump is no problem at all!
40psi is the stock pressure, so you should be fine :]
Old Jan 31, 2013 | 08:30 PM
stimsoni's Avatar
This is my stock 7. 18psi dropping to 16
UtahLuge
Lancer Aftermarket Forced Induction Tech
27
Jun 12, 2014 03:03 PM
brusinn
May 8, 2014 03:20 PM
68FBODY
13
Nov 4, 2011 04:26 PM
jrod4484
Apr 8, 2011 06:44 AM
Evojj25
Aug 6, 2010 08:04 AM
