Full acceleration to stop = stalling
Was there a solution for this issue?? Mine is Speed Density tuned but I'm experiencing this problem with and without higher acceleration & sometimes while turning too. Appreciate if anyone with knowledge could help me out, it's VERY unfortunate for it to stall so consistently, especially if traffic on the highway comes to a halt, it has even stalled before I'm able to come to a complete stop thus losing braking power and nearly rear ending the car in front of me. Why does it seem like only Evos have these kind of weird *** problems? I love the damn car but it's giving me every reason to hate it. FML.
So I was told about the car having idle problems once I got the car, so once I bought it I replaced the IACV from Mitsubishi. I've only put about 3.5k miles on the vehicle; will it go bad that fast considering I haven't driven on it much?
I had a similar issue that I was messing with for a while. I ended up finding a vacuum leak that caused the issue after trying different IACVs and MAPs.
For me, the leak I found was on the top of the throttle body where the EGR vacuum lines had been replaced with vacuum caps.
schuhie (Aug 1, 2023)
Vacuum leak, or could need to adjust the BISS some.
Update: I just checked the hose that I have looped and it doesn't seem like there is any visible leak. I doubt it but I'm wondering if having it capped instead of it looped will make any difference.
Alright, I'll check for vacuum leaks around the manifold & throttle body. Would it be safe to not check the lines behind the manifold since those are mainly EGR lines which I'm not using at all because I have the lines looped back to each other on the throttle body so basically the EGR vacuum system from the throttle body on is omitted already.
You shouldn't loop those two. one(FW side) is inside, the other is outside the throttle plate
schuhie (Aug 2, 2023)
ViciousLSD (Aug 2, 2023)
Originally Posted by ViciousLSD;[url=tel:11971300
11971300[/url]]cap them, with zip ties. or put something inside your looped hose to block airflow.
you can use them for a boost/vacuum or just boost gauge. I use mine to actuate a normally-closed valve
