Full acceleration to stop = stalling
Old Feb 7, 2013 | 04:10 AM
EVO TYME!'s Avatar
Sometimes, not all the time... if i accelerate fully and then sow down to a stop immediately after my car will shuttrr and stall. It starts right back up but is just annoying. Im thinking it could be smoothed out with a retune (which im getting shortly). I just wanted to get some input as well.
Evo 8, basic bolt ons i/e/ fuel pump / intercooler and piping, tuned on 24psi
Old Feb 7, 2013 | 05:03 AM
smoOVE's Avatar
that used to happen to me and i retuned and it worked out fine. sometimes on turns it would happen to me also
Old Feb 7, 2013 | 06:56 PM
hiboost2.0's Avatar
Was it tuned when it was warmer out? How cold is it where you live? I've noticed in the warmer months it doesn't do it at all, but in the cold months it can randomly.
Old Feb 7, 2013 | 07:09 PM
EVO TYME!'s Avatar
^^ Yes, It was like 90 out in the middle of July when I got tuned. I notice it alot more now that its chilly...
Old Feb 7, 2013 | 07:15 PM
fastyouth1313's Avatar
Are you still using MAF and using a differnt BOV that vents to atmospher?
Old Feb 7, 2013 | 07:28 PM
EVO TYME!'s Avatar
^Yes and yes, Greddy RS
Old Feb 7, 2013 | 08:10 PM
That's your problem. On MAF cars you need to recirculate your BOV back into your intake. Some tuners tune around as best as they can. That is 100% your problem.
Recirculate your vented air back into your intake and your stalling issue will be fixed.
Or get tuned for speed density and get rid of the MAF. Then you can vent to atmospher with no problem.
Old Feb 8, 2013 | 01:12 PM
thepoint4life23's Avatar
Mine Started doing this after puting upic on my car and a tial bov but it is recirculate. i have no boost leaks. will be getting a tune so so i hope that helps me.
Old Feb 8, 2013 | 01:18 PM
DsmGuy86's Avatar
+1
Mine did the same thing when I was on the maf and a tial 50mm bov, you eaither need to retune on speed density, or recirc the bov back to the intake.
Old Feb 8, 2013 | 01:57 PM
RussellDaniel's Avatar
I have the same issue and im recirculating back into the intake.
Old Feb 8, 2013 | 06:29 PM
hiboost2.0's Avatar
It's more than likely because when you let off, it's still very rich which will cause the idle to drop/stall.
Old Feb 8, 2013 | 06:31 PM
<p>It happens when I brake. Rpms dive to about 400.</p>
Old Feb 8, 2013 | 06:32 PM
Depends on how your tune setup is. Open loop or closed loop. You tuned???
Old Feb 8, 2013 | 06:34 PM
Closed loop
Old Feb 8, 2013 | 07:04 PM
Closed loop
If your modded. That's your problem. Get a tune. Have them set you up in open loop idle. Your stall issue will be gone.
