Full acceleration to stop = stalling
Old Aug 17, 2023 | 09:12 AM
  #31
ViciousLSD's Avatar
Originally Posted by Adroz
So I capped both lines and got to drive the car around, but I’m still experiencing stalling when coming to full stop. I assume theres a leak somewhere on the manifold but haven’t got to check it yet.
Try raising your idle rpm to 1k. just test it out to see if it changes things for the better. I set mine to 1k since I dont want the engine dying on me in bumper to bumper traffic with AC/other electronics in full blast and heavy clutch and all
Old Aug 22, 2023 | 12:35 PM
  #32
Adroz's Avatar
Currently the idle is already high like at 1100rpm which my tuner set it at to compensate for the cams. Ideally I rather have lower idle rpms but that sadly it isn't possible in my situation unless I go back to stock. I wonder if it could be my brake booster or line leaking since it mostly stalls while braking
Old Aug 22, 2023 | 01:10 PM
  #33
ViciousLSD's Avatar
maybe find a safe place to test that theory.
I'd keep a "backup" IACV. try the cheap ones https://www.ebay.com/itm/354209943724
Old Aug 24, 2023 | 08:14 AM
  #34
thepoint4life23's Avatar
Originally Posted by LetsGetThisDone
Vacuum leak, or could need to adjust the BISS some.
Can you tell me more about Adjusting the BISS Screw?
Old Sep 4, 2023 | 07:09 PM
  #35
Adroz's Avatar
@Vicious LSD I decided to try swapping my ECU back to stock and I did not have any stalling issues while braking. Maybe I need a retune? But before I get that done I’m going to change all the seals & idle adjusting screw on my TB because the screw head is stripped. My tuner said he could attempt to fix this issue if the screw was adjustable but I think my IAC and/or vacuum leaks can be ruled out since its not stalling while on the stock ECU, it even idles normal too.
Old Sep 8, 2023 | 06:51 AM
  #36
what way should i try adjusting the screw?
Bmurray
Aug 3, 2016 06:14 PM
Squirrley47
Jul 20, 2013 06:45 AM
tonyboy
28
Oct 5, 2012 07:17 AM
thiagobr03
Apr 2, 2012 04:03 AM
BMWE30
Dec 16, 2006 09:23 AM
