Comp has done it again an even better Stg 2 clutch option
Old Mar 10, 2013 | 10:22 PM
  #61
project_skyline's Avatar
Will the 4 puck and 6 puck shift just as good but with increased TQ holding capacity?
Old Mar 12, 2013 | 01:48 PM
  #62
Lucas English's Avatar
I would say since the burn down yes it has some lock out now Not crazy but it does. I have about 200mi on the road course, 3000mi on the street and around 25 1/4mi passes.
Yes the 6 puck and 4 puck will hold more TQ but the amount of extra heat created from those pucked clutches warp a single plate much faster then a full face disc does.
Old Mar 13, 2013 | 05:40 AM
  #63
SmoothCTR's Avatar
So would you say its locking out because you launched it 11 times in 1 day( specially the 4 last laps) ? Or is the clutch just not as durable as you had hoped for launching?
Old Mar 13, 2013 | 10:13 PM
  #64
Guess its a combo. I was trying to abuse it to see what it could take and I found out. Really was not the 11 passes it was 4 Passes with in less then 30min I did.
I Feel any car on Green or smaller turbo on a stock trans the clutch would live a pretty happy life at the drag strip. My 4.0 final drive is murder on clutches.
Still going to the road course this Sun with the clutch. Will report back again.
Old Mar 14, 2013 | 01:52 PM
  #65
Sloap2's Avatar
Might have to consider this my next setup. My oem is starting to slip a hair.
Old Mar 21, 2013 | 07:03 PM
  #66
Did 150mi around the road course in Seattle this Sunday. Turned a new PB for a lap time and the track and the clutch did great all day.
Old Mar 22, 2013 | 09:51 AM
  #67
DDATuned's Avatar
Lucas ,
Was it still notchy at high rpm shifting ?? I'm installing mine this weekend.
Old Mar 28, 2013 | 01:01 PM
  #68
8UpUrV8's Avatar
Lucas, any comparison to an Exedy Twin SD? Thanks
Old Apr 3, 2013 | 01:08 PM
  #69
JohnBradley's Avatar
Originally Posted by Remy
Lucas ,
That is not a common issue with this clutch.
That was only because of the added abuse of the 4.0 FD with a 2.0L instead of the 2.4 that had been in the car. Its fine on the street but after it heats up from launching after 100 passes it can be tempermental. If you are a stock FD and a 2.0L or 2.4 it will be a non issue.
Drives the same and shifts the same, holds up longer to abuse than the twin SD will. That particular clutch is not that great in our application though. Even the HD only holds up to 40-50 launches.
Aaron
Old Apr 3, 2013 | 01:12 PM
  #70
Originally Posted by nudge120
These flywheels weighed basically at exact same.
I know they were both weighed in the same manner but why is the scale on a tarp and not a flat surface?
Old Apr 4, 2013 | 05:50 AM
  #71
Rlee749's Avatar
Veteran: Marine Corp
I wish I saw this before I ordered the sprung version yesterday...
Old Apr 4, 2013 | 09:36 PM
  #72
DsmGuy86's Avatar
To make you feel better I have the sprung version and I really like it no issues with about 7 launches and hard driving for the last 9k still holding up perfect
Old Apr 10, 2013 | 07:51 PM
  #73
RSMike's Avatar
what is the clamping load with that kit?
3200lb?
Old Apr 11, 2013 | 09:14 AM
  #74
Still 3000# Mike.
Old Apr 14, 2013 | 07:41 PM
  #75
fafaforza's Avatar
Is this a good replacement for the stock clutch? Is the pedal not too heavy for DD duty?
I got my Evo cheap - slightly crashed - and it's my everyday drive. I don't really push it (got my bike for that) and I'm more interested in life and fewer parts/labor costs. Should I look at something else?
