Comp has done it again an even better Stg 2 clutch option
Old Apr 15, 2013 | 04:36 AM
  #76
SW20Mike's Avatar
Veteran: Air Force
^ I've got the Stage 2 sprung and it's perfectly fine for a DD. I had an Exedy stage 1 before and it was great as well, had a much stiffer pedal with the Exedy.
Old Apr 15, 2013 | 04:12 PM
  #77
rn.evo's Avatar
so would you pick the CC stage 2 over the exedy stage 1 anyday? Just wondering because my stock clucth is about to give up on me and debating whether to get the CC stage 2 or the EXEDY stage 1.
Old Apr 15, 2013 | 06:24 PM
  #78
SW20Mike's Avatar
Veteran: Air Force
I would get the CC stage 2 over the Exedy stage 1. The Exedy was great, held my power fine, but couldn't hold anything for a launch. Haven't launched the CC stage 2, but hear it holds much better. Both are great clutches, but I wanted something with more holding capacity.
Old Apr 18, 2013 | 09:12 PM
  #79
Lucas English's Avatar
The Exedy stage 1 is pretty much just a stock clutch. The comp will do a better job at holding a launch and more hp.
Old Apr 20, 2013 | 07:25 AM
  #80
mean4g63's Avatar
I have the sprung stage 2 comp. Not impressed with it in the least. Still has shifting issues at high RPM.
Don't waste your time, just go twin.
Old Apr 20, 2013 | 09:17 AM
  #81
JohnBradley's Avatar
How fresh is your trans? Is the clutch properly adjusted?
Old Apr 21, 2013 | 12:33 PM
  #82
The purpose of this thread was the unsprung which is much better then the sprung at high rpm shifting.
I would do this clutch over a Exedy twin since they have upper plate warping problems that will cause clutch dragging and lock out.
You are right in you cant compare this to a 7.25in twin in abuse and shifting but as a better alternative to current single disc its a great option at a good price.
There is no perfect clutch yet but comp and us are working on it.
Old Apr 21, 2013 | 01:34 PM
  #83
mean4g63's Avatar
trans 37k and yes. I had an OS Giken twin in my last evo. I didn't realize how good it was until my last few years of this. I think next time I will go with the quartermaster 8-leg, and freshen up the tranny for good measure and be done with it.
I got ya. Just sharing my opinion and experience on the sprung version of this clutch. This might swing a few people over to the unsprung version as this clutch can experience the dreaded lock-out in the sprung version.
Old Apr 21, 2013 | 02:06 PM
  #84
Fast_Freddie's Avatar
Veteran: Navy
I am in the market for a new clutch as the triple now has around 40K on it, but no launches, not slipping yet so just in the market... Would this be a viable option for a DD 2.4 with around 550HP, or do I need to look at other options such as the QM 8 leg?
Old Apr 21, 2013 | 05:19 PM
  #85
RSMike's Avatar
I'm really keen to try an unsprung stg 2 clutch, but i'm concerned about the torque holding ability.
I'm running a 2.3 with stock turbo and 4.111 final drive.
I'm currently about 400whp, with the hopes to run up to 500whp in the near future.
It is used on the street, and I will be using it for road racing soon.
I've got a 3400lb pressure plate, and trying to decide between the stg 2 or stg 3 clutch plate.
Have English Racing tried the stg 3 disc?
http://www.competitionclutch.com/pro...d=300&sid=2600
Old Apr 23, 2013 | 10:44 AM
  #86
fafaforza's Avatar
Does CC make a flywheel for the evo 8 or 9? Not seeing it anywhere.
Old Apr 25, 2013 | 03:53 PM
  #87
killerpenguin21's Avatar
whats the disc material (semi-metallic)? nothing crazy im guessing?
Old Apr 25, 2013 | 07:11 PM
  #88
They did offer a replacement flywheel that was a little lighter than stock. I will track down the part number and cost.
You know I am not 100% sure. I will find out though and post back.
Old Apr 25, 2013 | 09:39 PM
  #89
i see the "street series 2100" listed as carbon kevlar, just not sure if this is the same/updated version of that clutch.
Old Apr 25, 2013 | 09:58 PM
  #90
bitterchild's Avatar
my spring disc is carbon/kevlar. Bought it new a week ago.
