help with vacuum lines
Old Feb 19, 2013 | 06:11 PM
Fishd0's Avatar
Im running new lines and i cant seem to find the port off the turbo that tee's off the wastegate and runs to the stock boost solenoid.
Old Feb 19, 2013 | 06:48 PM
Ev0ikon's Avatar
Stock J-pipe has a nipple for it.
But I would ditch that HKS BOV. I saw it worked elsewhere but on an Evo. If you are on stock turbo/boost use a metal valve like that from an Evo IX.
Old Feb 19, 2013 | 07:18 PM
Fishd0's Avatar
I dont have stock charge pipes. So ur sayn pick up a stock bov for a evo 9?
Old Feb 19, 2013 | 07:51 PM
Ev0ikon's Avatar
Talking
You got it!
Or I think Evo8 MR are also metal.
Old Feb 19, 2013 | 08:01 PM
ak47po's Avatar
Do you have a stock hood?
Old Feb 19, 2013 | 08:17 PM
Fishd0's Avatar
No stock hood. What do i do about vacuum lune since i dont have stock j pipe?
Old Feb 19, 2013 | 08:19 PM
Fishd0's Avatar
Whats wrong with the hks bov?
Fishd0's Avatar
And should it not be venting to atmosphere?
Old Feb 20, 2013 | 01:30 PM
Ev0ikon's Avatar
If you are still using stock MAF you should not be venting to atmosphere no matter which brand of valve you decide to keep.
When you have time read up on old threads about the drivability of the HKS unit.
And if you don't have a boost reference off the cold side turbo you could just tap it to a port off the intake manifold.
Old Feb 20, 2013 | 01:36 PM
Tsensational's Avatar
Originally Posted by Ev0ikon
You got it!
They are plastic and apparently can get very leaky.
Old Feb 20, 2013 | 04:17 PM
Fishd0's Avatar
Could i tap it off the same line that the bov is connected to?
Old Feb 20, 2013 | 05:29 PM
Fishd0's Avatar
Got the lines all ran correct and it cured the fuel cut
Old Feb 20, 2013 | 06:20 PM
sparky's Avatar
You could try googling a product called, "FTG quick tap comphsg". It is an aluminum barb fitting that you install in a silicone IC coupler hose. I think that it is made by ATP turbo.
Old Mar 6, 2013 | 01:10 PM
Fishd0's Avatar
So i have a line coming from wastegat t'ing into a line off the im to the bottom port in solenoid. The from top port to nipple off the intake behind maf. Only boosting 13 psi. Wat gives?
Old Mar 6, 2013 | 01:23 PM
heel2toe's Avatar
Sounds like you are only running wastegate pressure.
I didnt completely follow what you said so I apologize but could you please expand on your routing? Are you trying to use the factory boost solenoid? If so you need to use the factory vacuum lines as they have a specific boost pill installed to help achieve the boost level.
