Hallman boost controller adjustments
Old Feb 13, 2004 | 04:34 PM
Reignman's Avatar
I got the Hallman evolution kit installed and Im having problem getting the boost set. I started by turned the knob all the way counterclockwise and the car maxed out at 14psi boost. I have tried turning it clockwise about 20 turns and I still am only around 16psi. Should it take this many turns to get this little boost? I would like to get it around 19psi but I feel like Im turning it too much and Im wondering if there is something wrong with the install. Anybody else have this problem?
Thanks
Old Feb 13, 2004 | 05:19 PM
propellerhead's Avatar
Do you have the Hallman Pro RX? If so swap out the spring for the heavier duty unit provided in the kit. I had the same problem. I had no problem accidentally hitting 25psi when I first set up the controller.
Old Feb 13, 2004 | 05:41 PM
Reignman's Avatar
I have the one with the knob that comes inside the car. I think its the RX. I got it used and didnt get another spring. Do you think I will be able to use the spring I have or do you think I should get the stiffer spring?
Old Feb 13, 2004 | 06:27 PM
I didn't fiddle with the lighter duty spring too much. I ended up cranking it ALL the way in and I think the max I got was 16 or 17 psi. I swapped out the spring and everything was cool once I got it dialed in.
Call Hallman. I sure they'll hook you up with a good spring.
Old Feb 13, 2004 | 06:52 PM
Reignman's Avatar
Thanks. I emailed them to see if they can send me the heavier spring. I was wondering if I could just get a spring at the hardware store but I dont know how heavy the one that comes with the kit is.
Old Feb 13, 2004 | 06:57 PM
GottaGoFaster's Avatar
I have the Evolution MBC and I had it installed with the normal spring. It took me a couple of turns but now I am hitting 20psi...but I do taper after 5500 RPMs...dunno why
Old Feb 13, 2004 | 07:08 PM
SuperchargedGTZ's Avatar
i have the hallman as well, and I have had no problems what so ever. I have the spring installed that came with it, and I had it dynoed at 310whp 294ft/lbs. it does take alot of turns to get it dialed in. It is a pretty fine adjustment. Good luck...
Old Feb 13, 2004 | 07:27 PM
Reignman's Avatar
So can I get up to 19-20psi with this lighter spring? As long as I can do that I dont mind the fine adjustment.
plokivos
84
Jun 7, 2017 11:25 AM
black_beauty
48
Mar 19, 2013 08:11 AM
evo jason
Jan 31, 2012 11:47 PM
delongedoug
46
Sep 7, 2011 04:04 PM
binky
28
Jun 7, 2009 07:26 PM
