One GIANT headache on this trans install
so basically (i just learned) you shouldn't turn the steering wheel too much if its not connected to the steering rack. I did, when i was putting things back together. That will break the clock spring part which is the electrical connection for the horn button and the airbag. No horn/SRS light on now. I ordered a clock spring and if cant find a srs reset tool then I think I might need to mail out my module to get it reset
yes. no.
so basically (i just learned) you shouldn't turn the steering wheel too much if its not connected to the steering rack. I did, when i was putting things back together. That will break the clock spring part which is the electrical connection for the horn button and the airbag. No horn/SRS light on now. I ordered a clock spring and if cant find a srs reset tool then I think I might need to mail out my module to get it resetWe've never done it, so I have an experienced it, so wouldn't know to warn you
yes. no.
so basically (i just learned) you shouldn't turn the steering wheel too much if its not connected to the steering rack. I did, when i was putting things back together. That will break the clock spring part which is the electrical connection for the horn button and the airbag. No horn/SRS light on now. I ordered a clock spring and if cant find a srs reset tool then I think I might need to mail out my module to get it resetMake a mark on both ends of the connection. Its usually greasy so wipe off grease and apply the mark. I recommend paint as a sharpie mark isnt durable enough.
You should mark it shaft before you disconnect it from the column. Center your steering rack so your tie rods are at equal distances (dead straight direction wise) and then reconnect the rack to the column. I pulled the subframe a couple times to either install a sway bar or clean the subframe. Sometimes its to easily remove the transfercase.
dsm nexus
Mar 23, 2014 09:00 PM
badev0
34
Apr 21, 2010 09:37 AM
elhalisf
Oct 15, 2005 05:37 PM
