Acd banjo bolt specs
Old Mar 4, 2013 | 11:24 PM
roblee8908's Avatar
I've searched and searched and have found no answers.
Does anybody know the torque specs for the banjo bolt located atop the transfer case on an evo 9?
Thank you
Old Apr 26, 2014 | 07:08 PM
blknblubkrdude's Avatar
Bumpity.... I want to know this as last time I tightened a turbo banjo bolt it snapped, and I ended up making my own bolt.
Old Apr 26, 2014 | 10:31 PM
TommiM's Avatar
Its not that much, maybe 10Nm. Its a hollow bolt and will snap easily. When I installed the AN fitting adapter to replace that banjo bolt that's what I torqued mine down to. It just goes on nice and snug.
Old Apr 28, 2014 | 04:59 AM
My thread pitch guage agrees with you! I was just worried about the softer material it is, and like you mentioned... the hollowness.
I looked through my FSM for nearly and hour... and was not able to find a spec. I did find a spec for the Power Steering rack banjo bolt, and it is 52ft-lbs! I believe it is a 16mm though.
I ended up snugging it up by hand... hopefully it doesn't leak.
Old Oct 14, 2021 | 06:34 PM
evl08's Avatar
Old thread, but this may help someone looking for specs.
The service manual calls for 44 Nm / 32 ft-lb.
ACD line banjo bolt torque spec
Old Apr 23, 2025 | 01:35 PM
Benz0407's Avatar
I am rebuilding my 2005 evo 8 from a roller so I just have buckets of bolts. I can’t find a banjo bolt big enough for the ACD hydraulic line that bolts on top of the transfer case. Would any of you happen to know the size and thread of that banjo bolt? Or where I can order it from?
eXtreme-Speed
Dec 30, 2016 01:27 PM
nikush
Oct 4, 2015 02:39 PM
cheedo
Aug 5, 2013 11:39 AM
b207
Mar 26, 2012 03:06 PM
shadoweclipse
Oct 17, 2011 05:26 PM
