White smoke out of exhaust when shifting gears
Hey guys I'm new to the community and also new owner of an evo 9 mr, I have this issue of white cloud of smoke coming out of exhaust when shifting. Help please
White smoke is actually steam - Oil from turbo seals burns blue/ gray / black. Oem turbos are water cooled but never heard of them failing and allowing coolant to reach the impeller area That would take a crack in the body. Headgasket is the classic cause of white smoke (Steam).
https://www.motortrend.com/how-to/wh...%20the%20cause.
White Smoke Coming From Exhaust: Explained
- White smoke from your exhaust means coolant is exposed to your engine's combustion process. In most cases, this is the result of a blown head gasket, but a cracked engine block or cylinder head could also be the cause.
- A compression test or cylinder leak-down test may be done to diagnose a blown head gasket, but the appearance of coolant in the oil (as a coolant-tinged foam) or oil in the coolant (as an oily foam) is a dead giveaway.
- A low coolant level and the need to repeatedly refill the coolant is a sign of leakage in the cooling system, and possible head gasket failure. The inexplicable loss of coolant and the appearance of white smoke (steam) in the exhaust go together like hand and glove.
- Besides exhibiting white smoke, another sign of a blown head gasket is that the exhaust will have a sweet smell, like the odor of butterscotch or graham crackers, an artifact of chemicals in the antifreeze being subjected to combustion.
- White smoke in the exhaust (steam) indicates vaporized antifreeze, which will coat and contaminate the car's oxygen sensors and set off the check engine light. Besides replacing a head gasket, you will also need to replace the affected O2 sensors for that bank of cylinders.
- A blown head gasket is most often caused by detonation in the combustion process. This is usually brought on by low fuel octane, oil contamination in the air/fuel charge, or excessive boost or nitrous injection in high-performance engines. It can also be caused by poorly performed repairs, a clogged injector, clogged fuel filter, or a marginally failing fuel pump.
I think we need more details. Are you getting white smoke under regular driving conditions and gear shifting or while doing "spirited driving" and how much boost are you running?
In addition to the above posts, you could be lifting the head under boost, if you are running a lot of psi, thus allowing coolant into the combustion chamber....just a thought, but more details on the driving condition is needed.
boom @mitsuatb
make sure you have a good catch can/pcv solution. those turbo seals wont last long if you have high crankcase pressure
mike_at_home
13
Apr 5, 2004 09:07 PM
