Evo 9 front axle (CV axle)
Old Mar 16, 2013 | 08:09 PM
turbotaloon95's Avatar
Originally Posted by kanovic
I highly recommend the new DSS stage 0 axles. Stronger than OEM, and CHEAPER! Otherwise don't bother with autozone crap as the majority of the time they are not the right size or thread pitch or something and will most likely break easily. I cannot stress enough to NOT buy off brand parts like this for your evo. DSS or OEM or nothing.
Old Mar 17, 2013 | 10:06 AM
BEKevo's Avatar
The customer tried to remedy his tranny/ transfer case leak by removing the OEM sealing "cup" (the sealing "cup" prevents fluid from being slung out of the output shaft seals of the t-case/ tranny) from the original axle to lancer axle, in his search to why his axles were leaking... Pretty hacked up job (ie he RTV'ed the cup in position) lol... In the end I found out the first 3 axles he purchased from the local auto-parts stores, were ALL the incorrect versions of the Evo axle, aka lancer axle. DSS or OEM looked like the only viable option at the moment, but we tried Rockauto.com and they sent us great replacement CV axle assemblies (x4) first shot.. I highly recommend rockauto.com for anyone trying to get OE replacements. Not everyone needs 1000whp rated axles.
Notes or comparison for anyone trying to find replacement CV axles for their Evo..
-First, the lancer axle will NOT have the tranny/ transfer case output shafts "sealing cup" on the axle. Immediate identification.
-Axles ARE SHORTER!
-Notice the beefiness of the Evo axle's in comparison to the lancer axles.. The cv- joints are bigger and so is the axles' diameter..
Attached Thumbnails Evo 9 front axle (CV axle)-img_1459.jpg   Evo 9 front axle (CV axle)-img_1457.jpg   Evo 9 front axle (CV axle)-img_1458.jpg
Old Mar 17, 2013 | 01:08 PM
hachansoo0413's Avatar
Originally Posted by BEKevo
All local autoparts stores will most likely sell you lancer axles (too short and the axle diameter is thinner, also leaks due to axles sealing incorrectly). Ive tried all of them, with no success.. Rockauto.com sells good remanufactured OE units (ie new boots and grease). I've used them many times with success.
I'll post some pics in a bit of a "right" and a "wrong" axle for you
Thanks sir!!!
Old Mar 17, 2013 | 01:12 PM
-Axles ARE SHORTER!
Do you perhaps remember the part number on rockauto.com for evo front axle???
Old Mar 18, 2013 | 12:10 AM
BEKevo's Avatar
Okay so apparently Rockauto does not have the right ones, as of right now.. Sorry guys. Im familiar with the "GSP" axle assemblies and "tough one"axles. They are the only ones I can recommend. They use more durable cv boots, compared to stock, (OEM) and use better grease to pack the joints (high moly content).. Both work great and are remanufactured OE units.
BUT... Advanced Auto currently DOES have the axles in stock. As of today, right now...
Heres the link to some axles (ie left & right) that will 100% work for you guys:
Right
Left
Old Mar 2, 2014 | 08:15 AM
Werdna06's Avatar
Advance auto parts passenger side does not seal against the oil seal. Driver side fits great.
Old May 4, 2014 | 03:07 AM
xXVicariousXx's Avatar
I actually just had my rear passenger side outer boot tear. Is it better to replace the whole axle, or is the OEM boot replacement sufficient enough? I guess in a way I'm fortunate that it's just the outer, but unfortunate that's its torn..
And it doesn't look like DSS sells the rear pair at stage 0 either.
Old May 8, 2014 | 07:22 AM
Werdna06's Avatar
how long has the boot been torn? if greater than ~200 miles i would just go ahead and replace the axle. if you search other sites you can find the stage 0's but the price my be a little higher but it's still lower than OEM.
Old May 9, 2014 | 04:22 AM
Yeah, it's probably over 200 miles by now. I just don't want a knock off that's significantly lesser quality.
Old Sep 9, 2014 | 06:09 PM
Koreyk1's Avatar
Does anyone know if evo 8 axles work in evo 9's, I'm new to this and I need to replace my axles, thank you!
Old Jan 22, 2015 | 07:43 AM
xteekayx's Avatar
I just wanted to resurrect this thread to see if anyone has used the SurTrack Evo axles from rockauto.com. Anyone?
Old Jan 22, 2015 | 04:10 PM
jarhead's Avatar
Drive Shaft Shop is the way to go. BTW if anyone is having bad deceleration noises due to after market internals, clutch, etc....all the rattles go away when the DDS axle is installed. 😁 The extra weight of the DDS calmed all the resonance. Best mod ever.
Old Nov 2, 2015 | 08:05 AM
iatmapotcmst's Avatar
so bump this thread, not wanting to spend $700+ on axles at the moment. several less expensive alternatives were mentioned, which is best?
Old Nov 20, 2015 | 11:11 AM
luvboost's Avatar
Originally Posted by hiboost2.0
I cannot stress this enough. Buy and OEM axle, I bought advance auto parts axle once.... The axle is physically too short. It will hyper extend the boots cause them to rip in a few hundred miles. Not only that but since they're too short the axle does NOT seat the seal on the transfer case/transmission. Causing both of them to leak. I was quick enough to realize this before my transfer case bit the dust due to lack of gear oil. Just buy OEM and don't look back.
EDIT: DSS axles I would assume were made with a lot more R&D compared to Advanced Auto Part's. If you do go that route do yourself the favor and compare it to the OEM axle and make sure they're the same length.
agreed. Don't buy cheap bull****. I bought used OEM axles just because I'd rather have OEM than a new advanced/Autozone crap. I'd rather have a used OEM axle off ebay than that junk.
luvboost's Avatar
Crap!! ****ing old threads. Let it die!!! I need to pay more attention
