Serious problems with my ACD transfer
Old Mar 9, 2013 | 02:03 AM
SrBlacksheep's Avatar
Guys i have a very bad problem with my evo VII, is pulling all the ATF fluid. My mechanic told me the problem is it have the RINGS broken inside the transmision/ACD transfer. So i had to turn off the pump to stop the pulling fluid. Now it have the three transmision light on (tarmac,gravel,snow).
Someone know when can i get the rings i need it? or what could i do?
thanks for all help you can give me.
Edward.
Old Mar 9, 2013 | 12:51 PM
Any opinion?
Old Mar 9, 2013 | 04:37 PM
Liqquid's Avatar
Is the ATF contaminating the gear oil then?
Old Mar 9, 2013 | 04:39 PM
matrho2792's Avatar
I would call Shep or TRE and see what they could do for you. Good luck
Old Mar 10, 2013 | 08:02 AM
yes it is, but i alredy disconected the atf pump.and we changed the gear oil complete.
Old Mar 10, 2013 | 08:20 AM
4RETECH's Avatar
Like mentioned before call Shep,Jacks or TRE.
Most likely you will have to pull the Transfercase and get the ACD seals fixed
Old Mar 10, 2013 | 01:15 PM
kikiturbo's Avatar
yes, you need to fix the ACD hydraulic piston inside the transfer box.. I do not know if you can buy it from mitsubishi... or just get a second hand transfer box..
Old Mar 11, 2013 | 09:28 AM
My mechanic told me is a ring inside the transfer and i need to change it that, but i dont know where can i buy it.
Old Mar 11, 2013 | 09:30 AM
how can i contact him? im new here.
Old Mar 11, 2013 | 09:31 AM
Old Mar 11, 2013 | 09:33 AM
4RETECH's Avatar
www.sheptrans.com
http://www.jackstransmissions.com/
Old Mar 11, 2013 | 09:45 AM
Thanks!
Old Apr 7, 2013 | 03:16 AM
Sax's Avatar
Sax
Hello,
I have this problem, the ATF fluid goes to the gearbox oil, is a problem from the transfer box?.
Thanks in advance
eflores
11
May 13, 2014 05:20 AM
Bui3s0ft
Jul 14, 2013 06:39 PM
evo9shane
Apr 8, 2013 09:55 PM
Svendiesel
Jan 4, 2010 07:58 AM
