Need a crate motor!
Old Mar 16, 2013 | 01:34 AM
asevo9's Avatar
Need a crate motor!
whats up fellas... long story short I need a new block
I am looking to drop in a completely new motor from scratch... i am hoping to build a street evo that would be able to pass smog (if it doesn't not really an issue but preferred). I live out in SoCal so smog lol. I have already checked some sites out like DSM Graveyard, AMS, Bushcur... etc and i havent really put a price limit on the build thus far so... im just trying to figure which way i want to attack it.
Also, what would be pros and cons of replacing just the short block VS dropping in a complete crate motor with brand new head, turbo, etc.? My goal is to get to the 400whp-500whp range on pump 91 gas and probably get a dual map for E85 . What would be the best route to go with as far as internals (pistons, rods, crankshafts) and im not really a fan of a stroker motors.
The car will be driven a lot so reliability is also important.
Thanks in advance for any advice
Old Mar 16, 2013 | 01:39 AM
sktng22's Avatar
why not just buy a used block and throw some manley i beams, wiseco hd, and a stock crank and youll be set. will probly be your cheapest route and will get you to where you want to be on the 400-500 range without the rods blowing out again.
Old Mar 16, 2013 | 01:41 AM
sktng22's Avatar
also to be in that range of hp it will be alot easier to get there with an aftermarket turbo as to a stock, so thats another reason to not go with a full crate motor and another stock turbo
Old Mar 17, 2013 | 10:10 PM
asevo9's Avatar
i havent been able to find any used blocks locally yet... would it be the same to buy it off a site like dsm graveyard?
Old Mar 17, 2013 | 11:01 PM
rs03evo's Avatar
Whatever you do stay away from Slowboy motors... if I were to recommend a block, I’d go with MAP Performance or English Racing.. That’s just my .02 Cents as far as staying Cali legal.. its hard I was in the same boat as you.. I was trying for a 500AWHP Stock Appearing engine bay but it’s pretty hard to do.. Not to say it can’t be done.. I shaved my cam gear cover, got a stock appearing turbo, undercover COP, ported my Exhaust Mani. And a couple other things to appear stock but the sound definitely gives it away at those power levels…
Old Mar 24, 2013 | 10:48 PM
asevo9's Avatar
bump
Old Mar 25, 2013 | 05:37 PM
jbuhrman's Avatar
Why can you not have the current block rebuilt?
Old Mar 28, 2013 | 01:15 AM
asevo9's Avatar
because there is a crack in it along with a piece the size of an oreo missing
Old Mar 28, 2013 | 02:58 AM
spdtckts's Avatar
Veteran: Army
you might benefit from checking out the vendors used parts section of the marketplace. they generally have blocks up in there for good prices.
tiktocca
Jul 15, 2019 11:12 AM
superkizuna
Dec 8, 2014 08:31 AM
DEBAUCHERY
May 18, 2012 06:46 PM
DonMitsu
South Region
Sep 20, 2011 08:13 PM
vince_w2004
14
Nov 15, 2010 12:30 AM
