Oil in exhaust port closest to passenger side
Old Mar 18, 2013 | 01:27 PM
rmorr79's Avatar
I did a compression test on my car and it showed 35 less on the cylinder closest to the passengers side. I pulled my exhaust manifold and noticed a lot of oil in the exhaust port of the low cylinder. I just had supertech dual springs and retainers, kelford cams, new lifters, and l19 headstuds a few thousand miles ago. Is this something that could have been caused by the installation of these parts or just bad luck. Thanks in advance for the help
Old Mar 18, 2013 | 11:54 PM
BEKevo's Avatar
Most likely bad rings or a leaking valve stem seal. Put a capful of oil in the spark plug hole (on top of piston) and redo the compression test. Tell us what happens.
Old Mar 18, 2013 | 11:57 PM
BEKevo's Avatar
I missed that part.. If you had this done by a shop, go back and request them to inspect it and express your concerns.. They should do it willingly.
Old Mar 19, 2013 | 08:48 AM
rmorr79's Avatar
thanks for the response. The compression did come up when the oil was placed in the cylinder. Im going to be pulling the head later today. Since the compression came up with the oil it would more than likely be bad piston rings correct?
Old Mar 19, 2013 | 12:29 PM
BEKevo's Avatar
Yes. Looks like you need new piston rings. And you can't blame the shop for the cams/ spring installation which is good.
Old Mar 19, 2013 | 12:36 PM
rmorr79's Avatar
yeah lol I really didn't think it was going to be something they did they do awesome work. oh well looks like its time to break it all down, build and up, and make some power
wiggam11
Nov 8, 2014 03:46 PM
xXANCHORMONXx
May 8, 2014 02:14 AM
butters149
Evo X How Tos / Installations
Feb 19, 2014 06:55 AM
riceball777
Aug 25, 2013 04:03 AM
ToxicFab
16
Oct 15, 2010 07:39 PM
