No good...
Old Mar 23, 2013 | 09:33 AM
DvlInDskyz's Avatar
No good...
So... recently I sent in my head to MAP to have some work and bigger valves installed on it. When I got the call about the work to be completed, the salesman said that the tech found particulate metal matter/shavings in head when they were cleaning it. So, he advised that I take off the oil pan to look at what may be down there and possible causes. I took it off and I found a thin metal "pin" piece that was about 1.5" long in there with a few shavings and that looks like it was bangged around. Anyone know what is this and what should be replaced in this case? I really don't want to send the motor back to MAP for a complete tear down and rebuild but if I have to, then I have to. Opinons of what this is and the fix? This can only be no good....
Thanks in advance!
Old Mar 24, 2013 | 08:05 AM
DvlInDskyz's Avatar
no one?
Old Mar 24, 2013 | 08:17 AM
JohnBradley's Avatar
was there bearing material in the pan or just that? Doesnt look like anything that would normally be on the inside of the engine though.
Old Mar 24, 2013 | 08:24 AM
Joshthree6three's Avatar
That looks like an oil squirters that has been owned by piston, rod, or crank. I'm willing to bet you have spun a rod bearing. The clearance of the oil squirters with the piston is very tight
Old Mar 24, 2013 | 01:24 PM
kyoo's Avatar
yikes
Old Mar 24, 2013 | 02:23 PM
ExViTermini's Avatar
Def one of the oil squirters, you have to bend them slightly to clear on a 2.3 setup.
Old Mar 25, 2013 | 05:47 AM
DvlInDskyz's Avatar
Thanks gents for the info. I believe you are right on the oil squirter. I am going to check it over tonight and see if that's the case. If so, is that something that the crank has to be removed in order to fix or is that something that needs to be machined and reinstalled?
Old Mar 25, 2013 | 07:53 AM
Take them out and weld them up. You can get them out without removing the crank.
Old Mar 25, 2013 | 02:34 PM
STiKillerr's Avatar
ouch that sucks man
Old Mar 25, 2013 | 08:53 PM
DvlInDskyz's Avatar
found the bad/broken oil squirter. From what I can see, doesn't look like it caused really any damage (that is visable at least which makes me scared). When replacing the oil squirter, what is the best way to clean out the thread holes in order to achive the correct torque specs?
Old Mar 25, 2013 | 08:59 PM
Wheatley's Avatar
I'd be more worried about all the metal that has circulated through the oiling system at this point. Bearings need to be checked at a minimum, oil pump and oil cooler if you have one. The reason I say this is if they found particles in the head that means its been pumped everywhere else. If it broke off because it was hit by a rod or piston then its the engine builders mistake or who ever installed the oil squirters.
Old Mar 26, 2013 | 09:50 AM
DvlInDskyz's Avatar
I agree. And I have to think of how to approach this with the builder/company.
Old Mar 27, 2013 | 06:06 AM
DvlInDskyz's Avatar
As a result, here is a short video of the underside of the piston that the oil squirter broke off in:
More problems = more $$$. Welcome to the world of high HP cars. I still love it.
BlueRalliart
Sep 21, 2014 04:52 AM
Levar
Oct 11, 2012 11:59 AM
chasesyellowevo
29
Sep 17, 2012 03:29 PM
blk-majik
14
Sep 17, 2009 07:01 PM
