EVO IX Turbo...Convert to Ball Bearing.
Old Mar 31, 2013 | 08:39 AM
heaveho's Avatar
The other company in the UK to speak to regarding upgrading the stock 9 turbo are Race Tech in Sheffield. I'm currently in discussion with them about rebuilding/upgrading mine, which appears to be using oil at the moment.
Old Mar 31, 2013 | 09:13 AM
EvocentriK's Avatar
Originally Posted by AutoXMRIX
You are correct about the magnesium exploding! Wondering if anyone has a titanium cartridge and something that's not an exploding magnesium.
The mag comp wheels from the 571 9RS turbos last years+ at 24psi no problems, not recommended above that. The best you'll get if you want spool bur more power than the 16G variants is using the TiAl TD05 turbine (available from any MHI evo turbo with 'TD05-HRA' in its code (the A denoting the TiAl turbine)), and a lightweight billet aluminium compressor. Like a BBK Lite but using a TiAl turbine. A local Aussie turbo shop (GT Pumps) builds them including an upgraded thrust bearing for reliability, killer response and midrange with great topend, 250kw/400nm on pump, ~295kw/450nm on ethanol.
heliarcpro
Apr 18, 2017 08:43 PM
Redefined
19
Aug 8, 2015 04:38 AM
ILoveAWD
Jan 4, 2015 05:52 AM
MJ23FE
Aug 19, 2013 08:37 PM
EVOEMS
16
Oct 23, 2012 10:27 AM
