Troubleshooting: Dead, sticking, soft Clutch Pedal
Old May 5, 2013 | 06:15 PM
NJ_evoIXgsr's Avatar
Veteran: Navy
The stainless steel braided clutch line was installed incorrectly/tighten extensively and after all the pressure it caused it to start leaking. Since our clutch line from master to slave is actually consisting of 2 lines. The fluid leak was actually at the center and not at the master or slave so I figured it was a second issue as it looked like it was coming from the transfercase!!!
Do not believe it is the clutch and replace something so PRICEY without all diagnostics done!!! thank god didnt buy an extra clutch for nothing!!!
Old Jun 25, 2013 | 01:16 PM
Rloera12's Avatar
Great write up man! I just finished putting my car together yesterday got a new clutch now to bleed it! :| but im glad it was not your clutch
Old Jun 25, 2013 | 02:42 PM
WRC-LVR's Avatar
Originally Posted by NJ_evoIXgsr
bump. Anyone have any additional input? If a transfer case leak can cause my dead clutch feel? As mentioned after bleeding it felt a lot better but it did feel like it needed to be done again. I don't want to waste my time with doing that if the tcase leak will cause more air going in.
In a word ..no the 2 systems are not connected . but i would chase that leak down once you are g2g. and stay on top of the fluids to ensure good levels at all times..the fact you got better for a bit and bled air means the clutch hydrualics are bad.
Replacement slave cylinders are $30 shipped from Rockauto including the banjo fitting. replace bleed and test. if it still is not good after some time but shows no leaks, then replace the master ...most likely an internal leak in that as well
My stock MR slave went at 30K and just like yours straight to the floor... I did have a leak that i found around the rubber cup on it. Dealer wanted 2 weeks and $120 for the part but seriously $30 Rockauto .......takes about 1 hour including bleeding...Use a friend or wife.
I use Brembo LCF600 in the brakes and the clutch is fed from that so i filled with that.
When the stock clutch had to be replaced at 76K, I re did everything in there, shafts seals rear main seal springs felt washers fork, new flywheel 6 spd clutch etc all brand new Mitsu. And I replaced the slave with another from Rockauto. I did not want to do something again in 15 K ..And just to be sure i have a clutch master on the bench in the garage. :-)
BTW just read about the leak on the joint in the line...Good find. and diagnostics I have the AMS 2 part kit but never installed it....prolly just put it up FS
Z_Lancer_Man
15
Mar 20, 2018 06:00 AM
kyoo
13
Sep 8, 2016 06:35 PM
vipevo9
Aug 25, 2016 12:36 PM
vaflyboi757
Dec 18, 2015 10:27 AM
gearheadvr4
Lancer Tranny/Drivetrain Tech
Jul 20, 2015 09:26 PM
