How to build a 4G64 for an EVO 8/9
I used a 2.4 belt but I have adjustable cam gears. With the 63 belt you have to adjust them 3 degrees retard I believe to compensate for the deck height.
So is there a reason why the 1994 Galant GS belt wouldn't work with stock cam gears? I understand most people just use adjustable gears to get around the length issue (and I understand the Evo IX timing belt is a nice piece), but what's stopping me from using plain old standard cam gears with the DOHC 4G64 belt?
2007 Mitsubishi Delica
2008 Mitsubishi Lancer
2008 Citroën C-Crosser
2008 Peugeot 4007
2009 Mitsubishi Lancer Sportback GTS
2009 Mitsubishi Lancer GTS
2009 Mitsubishi Outlander (Facelift Europe)
2010 Mitsubishi Galant
2013 Mitsubishi Lancer GT Manual
2015 Mitsubishi Lancer
I'm not trying to replace my X's 4B11, the question is in reference to a DOHC head swapped 4G64 8G Galant. Everyone seems to just say use an Evo IX belt and adjust your timing gears to make it work, but if the adjustable gears aren't necessary with a 1994 Galant GS belt that may be a superior option. I'm just curious if there's any reason why one can't run standard Evo VIII cam gears on a DOHC 4G64 with a 1994 Galant GS timing belt.
If you had g64 specific camwheels then it would fit perfectly.. in fact it would be good to check if something like g64 gallant GDI pulleys are the answer..
the issue is not the belt but the position of the tensioner pulley and the cam gears.. Due to higher deck the distance between the bottom pulley and cam pulleys is different, and it cant be rounded off to a whole tooth... that is the problem..
However there is a factory DOHC 4G64, the 1994 Galant GS came with a DOHC head on a 4G64 block, and therefore I assume the belt from the '94 Galant GS would be a drop in fit for this application without having to resort to adjustable cam gear trickery. Now if everyone's suggesting the Evo IX belt because they want to use the kevlar reinforced beauty the IX came with I understand, however is there anything stopping me from going to my local auto parts store and buying whatever Gates belt they stock for a 94 Galant GS and slapping it on my DOHC 4G64 with stock Evo VIII cam gears without futzing around with the adjustable gears?
I will repeat.. the issue is not belt length.. you can use any belt and you will always have a slight shift in the cam gears. both belts have identical tooth spacing, and the problem is that the higher deck height means that the cams are futher away from crank. Unfortunately that extra length does not correspond to a distance of whole tooth spacing.. so you are not one tooth off (which would not be a problem) but you are half tooth off..
Maybe if you used gallant cam gears..?
You can try gallant cambelt but it will still have the same problem..
I will check the gallant gdi cam gears.. maybe those are half tooth off..
Tracking now, it's a GEAR problem, not a belt problem. In case anyone's wondering, the Galant GS belt is exactly 1 tooth longer than it's Evo cousin, and Gates makes Racing Belt versions of both (T256RB-4G64 and T167RB-4G63). I will look for 1994 Galant DOHC gears, but I'm not going to hold my breath on finding one-model-year-only parts from over 20 years ago...
For the belt length issue, the 64 belt advances the timing by 3.5 degrees and the 63 belt retards the timing by 3.5 degrees. 1 tooth is 7 degrees and either belt puts it roughly a half tooth off. You need to the adjustable gears to set the cam timing back to zero.
The picture you posted with a half tooth off with the marking would put the cams off by 3.5 degrees if you lined it up with the cover. If you look at the dowl hole, its does not line up directly with the timing mark.
