How to build a 4G64 for an EVO 8/9
So whats the best way to go on the hg for the 2.1 4g64, is the bored out evo 9 hg the best out there? I was looking at the tomei head gasket but didnt find much info in the search button. My goal is to be in the 700-800awhp range so would it be better to o ring the block or the head? Or no o ring?
Hey Team, I have a 4G64 GDI Motor out of a Charriot (JDM 4G64 Engine), I know I can use a Stock Crank, and 156mm length Rods for a 2.1 Build, but I cannot find what pistons I can use? Anyone know what pistons I can run? The factory bore size is 87mm. Anyone know exactly what pistons I can run? Even a link would be good
I am putting a 4g64 2.4 together, stock crank, eagle rods, wiseco pistons, which balancer do i use? do i use a evo/4g63 balancer or one from a 2.4 4g64?
what is the part number? i dont want a fancy one like a fluidampr
Run GSC race shaft and delete the balance shafts... Save yourself trouble in the long run... Also get a fluidamper pulley highly recommend it
You realize those balance shafts are a bunch of bull**** right? There has been no technical info saying they are better then a stubby. At least not that I have seen. I am sure people will say oh well its right here. Personally I have never seen a pump fail with a stubby shaft in it without a fancy pos cut up one. I have seen pumps fail being people reuse them and do not put new gears into them from wear. But I do agree on the fluidamper
