How to build a 4G64 for an EVO 8/9
Old Aug 22, 2013 | 04:45 PM
  #241
joseph143's Avatar
Originally Posted by evolve_VIII
Mine seems to be holding up pretty well. The 2.4 spools the black very well. Hit 45 psi at 5200. Then it hit all the fuel/ignition cuts. At least that what the data logger shows. Pulled hard though.
Should have it on the dyno soon. Just switched to e85 so trying to flush out all of the old gas.
what horsepower are you hitting with 45psi?
Old Aug 23, 2013 | 05:01 AM
  #242
evolve_VIII's Avatar
Originally Posted by DormantBeast
So for the block gaskets would this gasket set work? Its shows its for a4g64 but doesn't show its compatible with the 03 galant... http://pages.ebay.com/motors/link/?n...d=221244111057
A few gaskets and seals will probably work. Honestly, I would stay away from cheap gaskets and seals. I would go with OEM or felpro. I use the EVO 8 engine gasket kit from AWD motorsports. It comes with every seal for a rebuild except a throttle body gasket. If youre going to spend the time to rebuilt an engine, do it right.
Old Aug 23, 2013 | 05:03 AM
  #243
No idea. Im guessing 700+ the way it pulled having driven in a few 700+ hp evos. We were not logging numbers, just dialing in the fuel maps and started playing with the EBS and timing.
Old Aug 23, 2013 | 11:50 AM
  #244
DormantBeast's Avatar
Alright sounds good thnx for the info... So other then the water pump nearly all the evo block parts work on the 4g64? for example oil pump case, thermostat housing, crankshaft sprocket, pulleys...
Does the girdle from the 63 work with the 64?
Old Aug 26, 2013 | 04:24 AM
  #245
The t-stat housing is part of the head to that will carry over with the swap. All the pulleys, tensioners, oil pump cover, oil pan, sump, oil scraper, ect.. will carry over.
As far as the girtle goes, I most likely cannot be carried over. Each one is machined to the block it was meant for. If you want to carry it over, you will need to have it align honed but I would not recommend doing that, hoping that its still on center with the block.
Old Aug 26, 2013 | 11:43 AM
  #246
just called a shop about the compatibility of the evo 8 gasket set on a 4g64 they said some parts will work others wont... anyone know what parts would not work?
Old Aug 26, 2013 | 12:58 PM
  #247
Well, I use all the gaskets with the kits except the water pump. They are the exact same block. Using a 2003 Outlander water pump gasket works. Since you are carrying over the evo 8 head, oil pump, oil filter housing and oil pan, all the gaskets are usable.
Old Aug 26, 2013 | 02:21 PM
  #248
ok cool, I actually have a 9 but that shouldn't matter still same block... cool thnx I'm asking cuz im buying like 80% of a master gasket set and didnt need certain things so I got them individually lol
just wanted to make sure so i can put in my order today
and yes i am getting a new 03 outlander pump for the block
Old Sep 10, 2013 | 07:30 PM
  #249
batty200's Avatar
Are there any stock 4G64 Cam gears that just line up or must you gamble with adjustable gears? My car has fidanza and I am suspect that the gears are not correct.
Old Sep 11, 2013 | 09:10 AM
  #250
I read in another post when doing some research that you can run the DOHC 4G64 gears with the 4G64 belt and they line up.
I went to the AEM adjustable ones because because Im running the 4G63 evo 9 kevlar belt. The adjustment makes up for the shorter belt.
The main thing to keep in mind is to have the dowl holes in the cam to line up with the valve cover marks.
Old Sep 11, 2013 | 03:33 PM
  #251
batty200's Avatar
The only dual Cam 4G64 I can think of is the old style Galant and those gears have different timing marks. Does the single Cam gear work just in a pair?
Old Sep 12, 2013 | 05:05 AM
  #252
The SOHC Cam gear will not work. My block was a SOHC engine out of a stratus and I held up the EVO 8 stock to the SOHC one and they were off.
Old Sep 18, 2013 | 05:11 PM
  #253
howell's Avatar
Using the 4g64 head gasket is there any modification needed? Any who has used the cometic conversion gasket? That is what was in my engine when I got it, and found that it is leaking under boost so now need to decide whether to go back to a cometic or try the OEM version. I know AMS used a 4g63 and ported the bore to fit the larger cylinders.
Old Sep 18, 2013 | 06:51 PM
  #254
batty200's Avatar
I used a stock gasket and have no issues and my motor is 10.5:1. I have stock valves with GSC S2 cams.
Old Sep 18, 2013 | 06:56 PM
  #255
Fast_Freddie's Avatar
Veteran: Navy
I use cosworth head gaskets for the 2.4L
