How to build a 4G64 for an EVO 8/9
Old Sep 28, 2013 | 09:54 AM
  #256
Frew's Avatar
Dont know if it was mentioned but does the 2.0 4g63 head bolt up to the 64 block with no work done to the head? On Buschurs site it says combustion chambers need to be worked to get it to work properly.
Old Sep 28, 2013 | 10:39 AM
  #257
st0mp860's Avatar
Why not build all the way?
Old Sep 29, 2013 | 07:17 PM
  #258
evolve_VIII's Avatar
I'm not sure about that. I called them and they said they cant tell their secrets.
My head bolted right up no problem. I did clean up the combustion chamber and port/polish my head. Nothing major to the combustion chamber though.
Old Sep 30, 2013 | 07:49 AM
  #259
92 GSR-4's Avatar
The answer is yes, and it will work just fine. The 4G63 head has smaller combustion chambers because of the smaller bore compared to the 4G64, but it works without issue. Buschur enlarges the combustion chamber to match bore size. To me, the only real change is that by enlarging the combustion chamber it will drop compression - so really you just need to plan what it is you're shooting for. There's a Kia/Hyundai motor (G4JS) that is a 2.4 almost identical to the 4G64 and it has the larger combustion chambers in the cylinder head. It's a perfect match for much cheaper if you wanted to use that, but the issue is that you have to use the entire Hyundai top end of the engine including their water pipe.
Old Sep 30, 2013 | 10:03 AM
  #260
batty200's Avatar
I wonder if G4JS Cam gears would work on an EVO. I am going to look into that.
Old Oct 9, 2013 | 11:13 AM
  #261
shrtstuff89's Avatar
So ive been having oil issues with my 2.4 lr.
Do i need the 4g64 front case or the 4g63 front case?
I ask this because although they are very similar, they have their few differences.
Old Oct 10, 2013 | 03:43 AM
  #262
2006GSR's Avatar
4g63 Evo front case.
Old Oct 10, 2013 | 09:05 AM
  #263
Ok. Thats what i have, but it seems to be leaking oil from underneath the lower timing cover.
I had to plug the hole on the back, drivers side of the block alrdy, so its not that
Old Oct 25, 2013 | 04:35 PM
  #264
Awd_evo's Avatar
So with the 2.4l block and 4g63 head , people with aftermarket camshaft do you guys degree in the camshaft to spec with an degree wheels or do you guys drop in camshaft at the stock tdc and adjust the cam gears ????
Old Nov 8, 2013 | 08:14 PM
  #265
howell's Avatar
outlander pump here. Put over 7000 miles in a month at 552/455 beating the **** out of it as a DD and driving it everywhere. leak free. Another friend has 1200 miles on his in a week and leak free etc. another one made 840/730 with no issues. another one is making 520 with no issues.
What head gaskets are you guys running and what head studs? I have heard of people having issues with the regular arp studs.
Old Nov 11, 2013 | 05:02 AM
  #266
Im running the OEM 8 gasket machined out to 87mm and ARP L19 studs.
Old Dec 23, 2013 | 12:58 PM
  #267
bzager1's Avatar
Veteran: Army
So there's no starter clearance issues with the stock Evo VIII manifold/turbo if you use the 4G63 starter? I've read several places a manifold spacer is needed to keep the turbo from hitting the starter, but I believe those folks are using the 4G64 starter...
Old Dec 23, 2013 | 04:10 PM
  #268
J_Striker's Avatar
No issue with the 4g63 starter.
Old Dec 23, 2013 | 04:50 PM
  #269
LaFuriaRoja01's Avatar
I've heard that with using an Evo 8 turbo on a SOHC 4G64, however I thought it wasn't an issue on a DOHC head 4G64. Either way spacers aren't expensive
Old Dec 24, 2013 | 12:04 AM
  #270
bzager1's Avatar
Veteran: Army
I gotcha, so the folks who needed spacers were trying to turbo a SOHC 4G64, the starter wasn't the culprit it was the head. DOHC heads with Evo VIII manifolds don't interfere with either the 63 or 64 starter then?
