How to build a 4G64 for an EVO 8/9
Old May 10, 2013 | 09:25 AM
  #106
ExViTermini's Avatar
I work on german cars for a living, and while BMW is the most solid of all of them, they dont hold a candle to the evo. Enjoy the 335 though, they're money pits for sure.
Old May 10, 2013 | 05:36 PM
  #107
bigdnno98's Avatar
I'll let it go after this post but I didn't spend a dime on maintenance on either of my 335is over the last 6 years. Last one was pretty highly modified and did 446HP/480TQ. Lets see, tranny broke 2 weeks after getting the EVO, TC broke first night at the drag strip and I blew an engine. Engine was more my fault but regardless. EVO has been a money pit for sure.
Old May 10, 2013 | 05:40 PM
  #108
bigdnno98's Avatar
OK so..... Here is what I'm doing. After talking to everyone from MAP to English and DB and AMS, I've decided to go with the following. Block and crank are at the machine shop now:
4G64 block: Bored .020, honed, decked, line bored, crank balanced and polished
no orings
no squirters
87mm cometic HG
1400HD Weisco Pistons
Map Ultimate Duty Rods
ARP main studs
L19 Head Studs
ACL Race bearings
03 outlander water pump
new oil pump
OEM balance shaft delete
Head was also shaved, it warped after I blew the head gasket
Old May 11, 2013 | 10:08 AM
  #109
Live4Redline's Avatar
no orings
no squirters
87mm cometic HG
ARP main studs
L19 Head Studs
ACL Race bearings
new oil pump
Looks good, what are you looking at for final purchase price on all that?
Still standing by my original comment and a small snicker at a price check of a 335i motor. Just an odd comparison, but hopefully you'll have better luck in the future.
Old May 11, 2013 | 12:29 PM
  #110
bigdnno98's Avatar
People don't blow 335i motors though. 725hp on stock block so far. Plus one of the smartest ECUa ever made too. Anyways
  #111
bigdnno98's Avatar
$25,000
https://www.evolutionm.net/forums/sh...2#post10794472
Old May 11, 2013 | 12:32 PM
  #112
bigdnno98's Avatar
Or did you mean price point for the motor? I paid $1900 for parts, $475 for block and crank, $600 at the machine shop, + labor. Prob $3800 all together with new oil and waterpump
Old May 11, 2013 | 12:37 PM
  #113
bigdnno98's Avatar
But I also sold my 2.0 block for $800 and have my 4G63 crank for sale for $250 so hopefully ill recoup $1050 and only spend $2750 on the whole new setup with labor. Not too bad I guess.
Old May 12, 2013 | 09:39 PM
  #114
mario's evo 9's Avatar
Have you confirm the 03 water pump from an outlander will bolt on strait to the block and not have any issues?
Old May 13, 2013 | 04:08 AM
  #115
Yes. The only 2 issues it has have already been mentioned.
Old May 13, 2013 | 04:57 AM
  #116
evolve_VIII's Avatar
Its bolts right up. However, you will need to trim one of the bolt mounts for the alternator bracket to line up properly.
Old May 13, 2013 | 07:12 AM
  #117
miragevo's Avatar
Veteran: Navy
Can you show a picture of what needs to be trimmed?
Old May 13, 2013 | 07:58 AM
  #118
For your evo9 you won't have to trim it, it only applies to the evo8 due to the alternator bracket. The pulley will potentially rub the timing cover a little as it sits in a touch. On mine I just shaved the cover a touch.
Old May 13, 2013 | 08:04 AM
  #119
Yes. Im going to post more pics once my build is complete and I hear it run this friday.
Old May 20, 2013 | 05:56 AM
  #120
It runs. Pics will be posted tomorrow morning.
