So what applications would it be used for ? is it purely for dyno numbers , drag racing ? would anyone daily drive or autocross on this little monster ?
where does it spool with strokers 2.3/2.4?
is it purely for dyno numbers: No....lots of people run them for various purposes. Originally Posted by Bcity
So what applications would it be used for ? is it purely for dyno numbers , drag racing ? would anyone daily drive or autocross on this little monster ?where does it spool with strokers 2.3/2.4?
drag racing: Sure you could use it for that
would anyone daily drive or autocross on this little monster : Sure why not, people have done crazier, there might be better turbos depending on how much you plan on doing this.
where does it spool with strokers 2.3/2.4: To many factors to give you a straight awnser.
Why exactly are you asking?
awnser.
not looking for a straight answer , looking for as low as to high as
Why exactly are you asking?[/QUOTE]
Lots of info on fp 3786r , cant find much on the 3794, trying to figure what turbo to run .
I dont want to run out of puff
40's to big 35s are to small .
awnser.
Actually you have it backwards, there is almost no information on the 3786. 3586 there is a ton and the 3794 there is a fair amount. The 3794 is best on a 2.4 and in my opinion MIVEC. A twin scroll application will work better but for AutoX it is the wrong choice.
Quote:
-Michael
What about pwr and spool difference between the 3786 and 3794?Originally Posted by Michael @ FP
It's the turbo you want to use if you want to make >750WHP. -Michael
Thanks
The 3786HTA will net around and extra 50HP over the standard 3586HTA and will spool around 300-500RPM later.
The 3794HTA is capable of around 900-950WHP and traps in the 170MPH range. The 3786HTA would be around 800WHP and would spool slightly sooner than the 3794HTA.
There's a reason there's not a lot of data on the 3786HTA most people are interested in that turbo we talk into a 3794HTA since it'll do what they want without being pushed as hard and spool comparable.
-Michael
-Michael
There are valid applications where the 3786HTA will work better than a 3586HTA but in the EVO world it's not a good fit.
-Michael
-Michael
Quote:
-Michael
Well I'm upgrading from a older t-67 p-trim dbb (pte6776) so most of the newer turbos including the 3794 should spool faster.Originally Posted by Michael @ FP
There are valid applications where the 3786HTA will work better than a 3586HTA but in the EVO world it's not a good fit. -Michael
Quote:
-Michael
I agree, a 3786 with the larger turbine wheel and a larger twin scroll housing would be killer. I am stuck between my desire to see this turbo first hand or just jumping to a 4205 on my car.Originally Posted by Michael @ FP
Understandable if you don't want to answer this - but the HTA3786R and HTA3794R, are they based on the same core as the T67BB ( / T04Z) or the one used on the GT3788R?
Quote:
No that was based off a T4 BB CHRA the 3786/94HTA use a GT35 CHRA as a base. So externally you can't tell it's not a GT35R. Originally Posted by MrLith
-Michael
do you guys offer a service to upgrade the 3586 to a 3786 ? or is that even possible if its not can you explain why since its 35r based thanks.
I'm guessing it isn't a GT35 hotside, so that answer was a bit odd. I had assumed it had the same turbine/hotside as a T04Z does but with an HTA compressor wheel but maybe it is something different again?
