how to 9000 rpm??
Old Apr 3, 2013 | 12:15 PM
GK007's Avatar
how to 9000 rpm??
hi fellas,
i want to target 9000 rpm with my 2006 EVO IX.
My engine head specs are;
-fp5r camshafts
-tomei exhaust cam gear
-power enterprise timing belt
-ferrea +1mm
-supertech dual valve springs
-oem valve guides
-full head port polish
supporter mods are;
-a/c delete
-egr delete
-ams race balance shaft eliminator
-ATI harmonic crank damper
engine specs are;
-pauter connection rods with arp625
-cp carillo 9,5 cr with skirt coating
-fp green hta 73mm turbo with fullrace headers+map external 02 housing
-aquamist hfs3 w/m injection system
is there any failure about my setup?
will oem crankshaft can support over 7500?
acl bearings or oem bearings for main bearings?
Can u share your experiments about high rpm setups?
Old Apr 3, 2013 | 12:29 PM
EvoJoeIX's Avatar
Whats the point of revving to 9k, your not making power there on a tiny fp green...
Old Apr 3, 2013 | 12:36 PM
escodotcarter's Avatar
Originally Posted by evojoeix
whats the point of revving to 9k, your not making power there on a tiny fp green...
+1
Old Apr 3, 2013 | 12:37 PM
GK007's Avatar
I target to make zero shift 100-200 on 4rd gear.. with larger turbos i have a spool on lower rpms..
especially 8600 rpm is enough for me to make zero shift 100-200 kmh
Old Apr 3, 2013 | 12:39 PM
todd6027's Avatar
buy a vtec honda
Old Apr 3, 2013 | 01:05 PM
EvoJoeIX's Avatar
If you can goto 8600 to hit 200kmh, it doesnt matter what size turbo you have. Unless you change your gearing, then you will always be at 8600 @ 200mh
With a bigger turbo, you will just get there faster
Old Apr 3, 2013 | 01:32 PM
GK007's Avatar
I also have an idea to upgrade my turbo but when i do it, i dont want to open head again. I want to build my engine with 9k+ reving capable but i dont use this capacity until turbo upgrade..
when i bought fp black or else turbos, i want to tight 4 bolts only on turbo.
Old Apr 3, 2013 | 01:58 PM
thepoint4life23's Avatar
stock crank can rev till 9000rpm
R/TErnie
80
Jan 7, 2021 02:46 PM
N33d4sp33d
12
Sep 26, 2013 11:09 AM
InjectedPerformance
Evo 'For Sale' Engine Internals and Drivetrain
17
May 11, 2010 01:58 PM
Conrad
Mar 8, 2010 11:26 AM
rodent
Feb 23, 2010 07:16 PM
