Bolts ons for FP Black Tune
I am looking to findout with my current mods with FP Green Setup....what else is recommended to gather before I go for Tune with FP Black Turbo ?
Current Mods: Setup made 430whp @ 27psi 379.37lb. Torque
2.0L 4g63 - Honed & Decked - 9.0:1 compression
Wiseco 1400HD Pistons w/ Howard Racing ( MAP spec ) Ultimate Duty Rods
ACL Race Bearings, S2 Cams, GSC Behive Valve Springs, GSC Race Balance Shaft Eliminator, ARP Main + Head studs, Kiggly HLA
Stock Transmission + Stock Transfer Case
FP Green HTA73 JB Turbo ( ported )
FP 18psi WA, FP oil Feed line, Spoolin' Up coil on Plug Ignition
JIC 1050 injectors, Deatschwerks 320lph Fuel pump, Custom Divorced 02 housing
Custom lower intercooler pipe, ETS 3" FMIC w/ ETS UICP mounted Forge BPV
ETS intake, Buschur Exaust system, Ported exhausted Manifold, Hallman Pro MBC
Omni 4bar Map sensor, EGR delete, Saikou Michi DC3 Dual Catch Cans
Torque Solutions 3 Piece Motor + Tranny Mount
Competition HD Street Disc Clutch w/ Lightweight flywheel
Bolt-ons that I've purchased for E85 FP Black turbo setup:
FP Black Journal Bearing w/ DUMP bolted onto Buschur ported exaust manifold
Double Pumper, ID 2000cc injectors,
4inch ETS Intake pipe Speed Density
ETS 4" FMIC w/ Curt Brown ported Intake manifold, 70mm Throttle Body
Question: Do I need any other parts, bolt-on, fuel to make upwards of 570whp
on E85 ???
on E85 ???
what is Grimmspeed 3-port BCS ? isn't the manual boost controller sufficient ? I see you're currently using S3 but will the S2 do the job at my HP goal ?
the 3 port is for ecu based boost control. The manual boost controller will get you to your goals, though.
Some tuners love 3-ports and some would rather manual boost controllers. Maybe talk with your tuner see what he recommends.
S2s will work. The S3s will just be a littler better on top end
Gotta kinda take into consideration if you're ever going to want more power then what your about to produce. I went with a 3.5in core. Pretty standard I believe and is efficient for quite a bit of power.
tscompusa
Oct 17, 2015 12:03 PM
EndlessRed
Evo X Dyno Results
10
Feb 4, 2013 04:58 PM
