Output shaft put in wrong side
Old Apr 6, 2013 | 02:59 PM
drakedeming's Avatar
I have an 04 RS, a rebuilt TC from shep with a wavetrac LSD. I took the TC out of the car 5 months ago and was working on putting it back in today. Turns out I put the drivers side output(long one) shaft into the passenger side of the TC. I have been unable to remove it even with a slide hammer. Is there something on the output shaft preventing me from doing so or are the output shafts identical other than length? Are there any tricks with the slide hammer? there is a tiny bit of play with the output shaft going in and out.
Old Apr 6, 2013 | 03:21 PM
joseph143's Avatar
If it doesnt come out in a few pulls try turning it... The circlip is wedged... Turn it 90 and push it jn then pop it out... If still nothing do it again...
They are identicle other then size yes
Old Apr 6, 2013 | 03:34 PM
Done for today, will try tomorrow. thanks
Old Apr 6, 2013 | 09:43 PM
Deeeeej1973's Avatar
If it makes you feel any better, mine were backwards like that when I purchased my evo! And I didn't find out until the "ebay" clutch disk that had been previously installed took a crap...
Old Apr 7, 2013 | 06:09 AM
I do not think it would be possible to reassemble the car the way these are, they are switched not backwards.
Old Apr 7, 2013 | 02:49 PM
Still will not come out. is it possible the ring snapped inside and jammed it? The TC is out of the car and we tried it while holding the TC at different angles also.
Old Apr 7, 2013 | 09:31 PM
MRfabolous's Avatar
where are you located at in MD need any help
Old Apr 8, 2013 | 04:19 AM
I'm actually in Leesburg Virginia now, I am going to try banging on it a ton today after work and my father in law my work on it also while I am at work.
Old Apr 8, 2013 | 02:05 PM
Hammered it with a slid hammer for a good half an hour and nothing. Can I hit it with an extension from the other side?
Old Apr 8, 2013 | 04:11 PM
blowngasket's Avatar
I had mine stuck in my old Tcase, Issue with hitting it from the other side is there is a Center pin right down the center so you need something that would fit inbetween that and the Front diff.
Old Apr 8, 2013 | 05:03 PM
Shipped it back to chep to take it apart, I was worried about damaging the LSD.
Rom
Feb 20, 2017 11:48 PM
Jonno99
Aug 10, 2016 08:30 PM
letMeIn
Jul 18, 2010 01:49 PM
varner88
12
Nov 5, 2008 09:28 AM
zkb
Aug 17, 2008 11:59 AM
