GSC R2's with Supertech duel valvetrain is a NO GO
Old Apr 26, 2013 | 03:43 PM
  #91
EvoJoeIX's Avatar
I believe aaron runs kiggly
Old Apr 26, 2013 | 06:36 PM
  #92
kpr's Avatar
kpr
Lol good cause I've had these cams in my car for 2 wks
Old Apr 26, 2013 | 10:35 PM
  #93
browningderek's Avatar
Theirs one guy on here that dropped them in a buschur head. I wonder how his car is doing... it was just too darn close for my taste. Moral of this thread is always check it!
Old Apr 27, 2013 | 03:16 AM
  #94
tscompusa's Avatar
Originally Posted by browningderek
By locators I think he means spring seats. Gsc says right there on their site to use OEM spring seats. The super tech seats are for duel springs only.
*update* I installed the gsc 5041 spring set. It gave me an extra .030" of retainer to seal clearance which was just what I needed! So now I just need to verify cam timing is correct and I will be putting my engine back in.
Old Apr 27, 2013 | 05:41 AM
  #95
michaelrc51's Avatar
Yes, I meant the spring seats or as Dave refers to them as locators. I spoke to him when I was going to swap the valves out and he made sure I knew to have OEM spring seats. I don't do this stuff often so I appreciate his assistance otherwise I wouldn't have figured that out until I had a spring off.
I just posted this info cause I didn't want anyone else to possibly do the same thing.
Posted from Evolutionm.net App for Android
Old Apr 27, 2013 | 08:12 AM
  #96
For sure michael! That's what this thread is for.... information. I'm putting my engine back in today.
Old May 28, 2013 | 01:02 PM
  #97
Finally got the engine back in and running. The gsc 5041 spring set worked like a charm. I also installed the gsc seals and had plenty of clearance.
After degreeing the cams in it ended up 3 degrees retarded on the intake and 5 degrees retarded on the exhaust. FYI these cams pull 1 less inch of vac than my buschur cams but seem to idle smoother than the bf cams. Weird.....
I hope to get a good back to back test of my can swap in the next few weeks.
Old May 29, 2013 | 05:09 PM
  #98
03whitegsr's Avatar
I thought GSCs had tight machining tolerances and were typically within 1*?
Reguiring 5* seems like that cam was out of spec. Or maybe you used a different method to determine lobe centerline then they intended?
Old May 30, 2013 | 05:23 AM
  #99
No, 3 intake and 5 exhaust. My block and head has been milled so that's why they were a few degrees retarded. That's normal. The cams were only 2 degrees off of each other, give or take 1 degree of course.
So if I had a bone stock motor I would think these cams would go in straight up just as gsc says. Maybe 1-2 degrees off which I consider normal.
Old May 30, 2013 | 07:46 AM
  #100
03whitegsr's Avatar
Milling the head 0.010" only accounts for like 0.2* of cam retard. It is hardly anything.
Could also be the accuracy of the cam gears.
I suppose either way it shows it is worth degreeing in the cams if you aren't going to tune the cam gears on a dyno.
Old May 30, 2013 | 10:39 AM
  #101
Buschur thought it was a good idea to cut the head/ block so far that the pistons hit the head! I'm had to use a thicker Evo 9 hg to keep it from hitting so I would say my engine is off more than normal. I used adjustable cam gears but I didn't pay any attention to the marks. I degreed and set them. The "stock" marks weren't even close.
KnucklesVIII
Nov 26, 2016 11:51 AM
workel2man911
Mar 24, 2016 03:41 AM
sketchy mark
23
Jan 14, 2016 05:45 AM
ilikeppie
Sep 17, 2012 03:39 PM
Spoz2435
Lancer Engine Tech
31
Jul 17, 2010 03:05 AM
