full blown fuel filter
Old Apr 9, 2013 | 08:25 PM
DvlInDskyz's Avatar
I recently purchased a Full Blown fuel filter and am wondering who has installed one of these on ther car or someone elses and where they installed it?
Old Apr 9, 2013 | 08:28 PM
701evo's Avatar
I beleave it's in your fuel tank If that's what your wondering. Make a how to if you do it!
Old Apr 10, 2013 | 08:34 PM
DvlInDskyz's Avatar
thanks but no... not the filter on the pumps themselves but the nice billet one externally. anyone?
Old Apr 12, 2013 | 09:42 AM
DvlInDskyz's Avatar
has anyone mounted this in the engine bay or close to it? Or is it better to keep it closer to the tank itself?
Old Apr 23, 2013 | 07:38 PM
DvlInDskyz's Avatar
Should anything such as a sealent or telflon type tape of some sort ever need to used on the threads of -AN fittings when connecting them together?
Old Apr 23, 2013 | 08:06 PM
superbovine's Avatar
The -AN fittings should be self-sealing flared ends. If you have an -AN adapter with pipe fitting on one side and -AN on the other, you would need to teflon the pipe thread side.
Old Apr 23, 2013 | 08:22 PM
DvlInDskyz's Avatar
What I thought but wanted to double check. Thank you for the info!
Old Apr 24, 2013 | 07:30 AM
evolve_VIII's Avatar
You can mount it anywhere. Im probably going to mount mine on the firewall for ease of servicing and cleaning out the filter. The main point of the inline is to catch any debris that may make it into the lines from a failed fuel pump so it doesnt destroy your injectors. Your tank already has a sock on the bottom of the pump.
Also, the filter should be between 50 to 100 microns of filtering. If its too fine, you will only make a restriction in the fuel system and starve the injectors.
EvO_essence
Aug 11, 2016 07:57 AM
MitsuJoe
Aug 29, 2011 08:39 AM
MarksIX
19
Oct 21, 2010 12:18 PM
precisionpsi9
Jan 30, 2009 07:32 PM
EVOllie
Mid-Atlantic Region
Aug 9, 2008 04:46 PM
