View Poll Results: If you are running a 10w30 oil which of these oils would you use?
I would chose brand x
29
55.77%
I would chose brand y
9.62%
I would chose neither
15
28.85%
I would chose both
5.77%
Voters: 52. You may not vote on this poll
Evo engine oil experiment: Would you run this oil?
Cool, in for results. I keep meaning to send my oil in for analysis. It would be nice to know if my current 3000mi oci is necessary or if I can extend that. Its also a great way to gain insight on to the condition of my engine. Of course this thread is geared solely to the oil which is sort of a different angle. My only question though is the specs of an unused oil may be up to par but how do they hold up after said amount of miles I think is more important.
I am having them do a TBN so that should give a little more info.
After reading this: http://www.blackstone-labs.com/do-i-need-a-tbn.php I am a little confused to be quite honest. The TBN ranges from 6-14 and the larger the number the more additives the oil has. In theory the more additives the longer it will last, correct? Sorry I'm new to the oil analysis world, have never done one and have a ton to learn. I dont mean to cause this thread to go OT so if you prefer I can ask these elementary questions in your sticky, or better yet simply start reading.
The point I would like to make clear is that it isn't a comparison of these two oils, necessarily. Its more about would you run these oils in your evo? So you like brand x, but the question is would you also run brand Y in your evo? why or why not?
Yes MAP has oil reqs. for their turbo.
from: http://turbos.maperformance.com/evo-turbos.html
All synthetic oils are not created equal! In fact, the majority of synthetic oils on the market seem to be more concerned with fuel efficiency and emmissions compliance than wear protection and longevity! We recommend you choose from the following motor oils based on their high ZDDP content and corresponding wear protection. We've even included a few conventional petroleum based options that can be sourced for less than $5/quart if budget is a concern. Please contact your MAP sales rep with any questions regarding motor oil weight recommendations or availability.
