Missfire at WOT?
Old Apr 17, 2013 | 09:32 PM
88888's Avatar
Angry Missfire at WOT?
Hello all, my car is misfiring at WOT and was wondering if you could help me out find out the issue
buschur built motor with fp black running 30 psi.
1. im running on pump. I have ran fuel injector cleaner so injector should be clean
2. i have just replaced my sparkplugs. same plugs same gap (.025)
3. im running spooliin up COP. its been on the car for about 10k miles
What should i try replacing next? COP?
and advice/ inputs would be helpful
thanks
Old Apr 17, 2013 | 09:42 PM
3K's Avatar
3K
Gap your plugs to .020
Old Apr 18, 2013 | 09:20 AM
Thore's Avatar
+1 at .020.
If that works, you can experiment a little bit increasing the gap without recreating the misfire.
Old Apr 18, 2013 | 10:40 AM
88888's Avatar
I will try that.
but with me running same setup same type of plugs and same everything else, i dont see why smaller air gap would be necessary on this new plug..
Old Apr 18, 2013 | 10:46 AM
Travis@GSC's Avatar
check for loose connections at all the COP connectors. Also gapping the plugs down should help.
Old Apr 18, 2013 | 10:52 AM
boosted91t's Avatar
I agree with the others, drop the gap down. I run as low as .017 in high boost applications on stock coils. What spark plugs are you running?
MrEvo9Mong
Dec 8, 2016 08:56 PM
xRoguex
Sep 22, 2013 05:31 PM
stunt2
May 14, 2012 04:45 PM
DormantBeast
Mar 28, 2012 10:41 AM
Srt4...
Jun 25, 2011 03:02 PM
